Please critique my first compressor design (for bass guitar) - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 2nd September 2013, 08:58 AM   #1
Default Please critique my first compressor design (for bass guitar)
Hello everyone.
I have at home a bunch of EBF89 tubes so i figured i try something new with them. I know, that they are not good for audio use, but im still in the phase of learning, so i think they are the perfect tubes for experiments. If this experiment gives me something usable i would like to implement it in a bass tube preamp (most likely a Alembic f2b copy).
For the last two weeks i have studied some compressor designs and came up with this schematic:
Im still not satisfied with the design. First of all im not really sure im using the remote cutoff function of the EBF89 correctly. Im thinking about grounding the cathode and using the LDR as a regulator for negative voltage from a separate source. Secondly i would like to have the control over the threshold, attack and release. I would greatly apreciate any hints.
A note: i dont have a EBF89 spice model so for simulations i used a bit different connection (just different values of R1 and R4) and a EL84 (i know its not a good replacement) and the compressor worked.
Thank you for your answers.
vertical line cabinet design for bass guitar tapehead ted Instruments and Amps 25 29th August 2012 12:18 AM
Guitar/Bass-Guitar Loudspeakers used as Bass-Midrange for Home Audio Applications tiefbassuebertr Multi-Way 2 23rd April 2012 04:40 PM
small preamp design for a bass guitar Gene_Johnson Instruments and Amps 42 25th November 2009 04:12 PM
Bass guitar amp design guidelines Bill622 Instruments and Amps 12 1st December 2008 09:25 PM
any suggestion for limiter and compressor for a bass guitar ? Ahmad_tbp Instruments and Amps 4 27th January 2006 09:53 PM
Copyright ©1999-2017 diyAudio
