Piezo Film Buffer and Amp Combo for Guitar Electronics - Page 3 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 27th August 2013, 09:55 PM   #21
Lid55 is offline Lid55  Canada
Yes Nigel is right, the level of the piezo film is very low... it is possible to get piezo film that outputs a higher level, but right now it costs 20x the money... because it's non standard. I've already tried the buffer circuit alone extensively, it sounds great (balanced frequency spectrum), but in order to hear it I have to max my computer's external audio card, and the amount of noise is unacceptable.
Nigel, do you know... if I ran the signal through both sides of the OPA2134... would any of the circuit component values change the second time around (i.e. after the first opamp in the 2134)?
Old 28th August 2013, 08:19 AM   #22
You don't need a high impedance input on the second amp, as it's fed from a low impedance source (the first opamp).
Nigel Goodwin
Old 31st October 2013, 09:48 PM   #23
Hey there, I've finally found some time to dig into this circuit, my updated circuit is in the PDF attachment. I've added annotations (small green text) regarding what I've found in my research, if you want to read them you have to zoom in.
So far, I've found that using the buffer circuit really helps in balancing the lows, so I've ruled out using the opAmp circuit alone.
Any notes regarding potential optimizations of this circuit are appreciated.
Specifically, I am looking for information regarding the main tone shaping components in the circuit. Would it be fair to call C1, C3, C5, and C8 all "audio coupling capacitors? Also, would I be right to call this an AC circuit, or is it also necessary to think about it in terms of DC?
Thanks for the responses thus far,
- Brett
Old 1st November 2013, 03:01 PM   #24
Yes, all are coupling capacitors - although there seems no point in having both C3 and C5 (or R5 at all).
You don't use coupling capacitors for tone shaping, their action is far too gentle.
Nigel Goodwin
Old 1st November 2013, 03:32 PM   #25
Thanks for the info Nigel. I found online the equation C(new) = (C1*C2)/(C1+C2)... and calculated the result to be .018uF.... so... then... I would just leave the .022uF capacitor and get rid of C3 and R5?
I haven't figured out measuring impedance yet... but I'm thinking that might be the next step.
Old 1st November 2013, 03:57 PM   #26
mjf is offline mjf  Austria
hello.
R5 can be seen as a damping res against hf.......
you should swap the position of c8 /r10 (or you will have some dc current through the pot).......
if you do not really need the pot (r10) you can leave it out.......
Old 1st November 2013, 03:59 PM   #27
Assuming you're wanting a 3dB/Oct bass roll off then 0.022 should be fine, but it's not really very much of a roll off.
Measuring the impedance of what?.
Nigel Goodwin
Old 1st November 2013, 04:07 PM   #28
Originally Posted by mjf View Post
hello.
It's not a valve amplifier
Nigel Goodwin
Old 1st November 2013, 07:54 PM   #29
So would a higher value cap create a steeper roll off? For example, a 1uF cap might provide a 6dB/Oct bass roll off? I thought a cap here would more affect the cutoff frequency... or does it control BOTH cutoff frequency AND roll off "Q"/slope? Ideally, I'd like a fairly steep roll off at about 60Hz.
I was thinking it would be enlightening to measure impedance at the output of the first circuit and the input of the second circuit. I was thinking this would help with knowing the right value capacitor to place there... for the most transparent audio signal.
Old 1st November 2013, 08:03 PM   #30
well I need the pot (at least SOMEWHERE in the circuit)... as this is how I am adjusting the volume after the circuit is installed in my guitar....
so simply swap C8 with R10? mjf, I noticed you swapped the polarity of C8 as well... was the original drawing of the circuit (that I got online) wrong? I've tested the original circuit out already and the cap hasn't exploded... doesn't this prove then that some directional caps be used unidirectionally?
Pre Amp/Buffer and Amp for a Ukulele with an under saddle Piezo pickup Rich3761 Solid State 3 28th February 2013 02:48 PM
Film Trailer: State of Electronics (aussie) col Everything Else 1 2nd November 2010 12:56 AM
guitar amp enclosure/combo cabinet Aidan135711 Multi-Way 9 6th May 2010 07:43 AM
Piezo film used in 300 degree radiated tweeters humanhuman Multi-Way 2 18th November 2007 02:28 AM
Guitar Amp Question!!!!! Adding Film Cap? zxx123 Instruments and Amps 11 29th March 2005 01:50 AM
Copyright 1999-2017 diyAudio
