Hot Cathode Follower Resistor - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 3rd August 2013, 02:25 AM   #1
Default Hot Cathode Follower Resistor
I have two DC coupled cathode followers; one with 100k and the other with 47k off the cathode.
Both resistors are hot to the touch even when idling. Measurements show they are drawing less than half a watt. I changed one of them to 2W but it is too hot as well.
There is also fairly nasty hiss at high gain settings. The heaters are DC and regulated. Because of the poor power supply regulation, the voltage going in had to be raised to avoid dropout when the amp is pushing full power.
As a consequence, the rectifier and the regulator are running so hot, eggs could be fried on the heatsinks. In fact, the diode pack didn't even have a heatsink when I got it. I wonder if thermal noise is being generated there.
Otherwise, the amp works and sounds perfect. I know the regulator situation has to be remedied, and it will. But why are those resistors so hot?
Any ideas much appreciated.
Venturing where the wise refuse to go, may or may not yield great revelations theretofore unknown; either with considerable expense.
Old 3rd August 2013, 05:21 AM   #2
azazello's Avatar
Schematic please....
Old 3rd August 2013, 05:26 AM   #3
They both have these, too.
The V4 has the 47k. C = 350V
Old 3rd August 2013, 06:28 AM   #4
jan.didden's Avatar
How did you measure the dissipation? Not clear to me which resistors you talk about; when you say 'off the cathode' do you mean the cathode resistor or some load resistor?
I see in one schematic a 100k cathode resistor with 212V across it - that would be less than 0.5W.
A 47k with 350V across it would dissipate some 2.6W and that one would definitely be hot.
What is the total current the amp draws from the supply? Did you measure that?
In the upper schematic, V3a output seems heavily attenuated and that could account for the high noise. But the circuit doesn't seem to be right - why the high attenuation?
jan
I won't make the tactical error to try to dislodge with rational arguments a conviction that is beyond reason - Daniel Dennett
Check out Linear Audio Vol 7!
Old 3rd August 2013, 07:19 AM   #5
Thanks for answering. This is very bewildering.
C = 340
PS DC Amps = 8mA Two other 12AX7 dual triode gain stages are also being powered.
V across R25 100k on V3A is 167V = 0.28W That one is not noticably warm with 2W metal film resistor.
V across the 15k on V4B is 43v = 0.12W Also not warm with 3W resistor.
V across the 47k on V4B is 133V = 0.37W Too hot with the same 2W metal film resistor as R25.
The attenuation on V3 output is to bring the output to pro equipment level which I understand is about 2V. Tapping further down, or reducing the 2.2k to ~ 200R will bring it closer to instrument level (~100mV) at high gains and medium inputs.
That resistor is currently a 0.5W carbon pot.
Old 3rd August 2013, 08:05 AM   #6
jan.didden's Avatar
C = 340
Attachment 363933
Maybe your idea of 'too hot' is too restrictive. If you can barely keep your finger on it, that will be about 45 degrees Celcius which is not hot at all for a resistor.
Are you sure the resistor value is correct? It's easy to make a mistake with one of the color rings and be a factor of 10 off.
Still puzzled about that 1st stage. The attenuation on V3a appears some 45 times, that's a waste and may be the cause of the noise.
You should chuck the gain stage and use just the cathode follower, much better!
Edit: taking away C11 on V3b will give better performance and lower gain, that will help already a lot!
jan
Old 3rd August 2013, 09:09 AM   #7
It has no bands, but it's the size of a 1/4W. I think Mouser made a mistake. One time I got a bag with no resistors at all!
The level has to come down somehow. I don't know how else to do it. Perhaps the total resistance could come down, then readjust the divider. If 100k is faithful, and 47k clips half the waveform, then I guess ~85k would do no violence
Can't do that, that stage colors the sound and would upset the chain. Better to leave well enough alone.
I will try that.
Thank you so much. Back to rubbernecking....
Old 3rd August 2013, 09:54 AM   #8
jan.didden's Avatar
Well how do you know it is the right value then?? Has it text?
jan
Old 3rd August 2013, 10:20 AM   #9
It says 47k and measures the same. I looked up the code in Vishay Dale and it says it's 1W.
Ok so it's not 2W, but it's still more than twice the rating necessary, yet too hot.
Old 3rd August 2013, 10:20 AM   #10
SY's Avatar
Either don't amplify (as Jan suggested, remove the gain element) or put a volume control at the input. Your scheme increases noise and output impedance.
Other thing to note is that cathode followers can oscillate easily- they're operating under 100% feedback. This is a common source of noise; you can't hear the RF, but you hear the effects. You want local bypassing of the plate, and grid stoppers placed physically as close to the grid pins as possible.
You might be screaming "No, no, no" and all they hear is "Who wants cake?" Let me tell you something: They all do. They all want cake.- Wilford Brimley
Hot follower/cool follower webercarbmann Solid State 13 2nd November 2010 02:23 PM
Hot Follower 99 MEGA_amp Solid State 25 7th March 2010 08:00 PM
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 06:47 PM
cathode follower ackcheng Tubes / Valves 2 6th July 2004 03:12 PM
hot follower UrSv Pass Labs 2 25th September 2002 04:49 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
