OPT impedances - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 18th July 2013, 07:04 AM   #11
osci is offline osci  Australia
Jim,
I got around to testing the smaller 5watt output transformer last night and I wouldn't recommend using a small tranny sucj as the 5 watt on a circuit such as the GA-8t which is what I've just built.
I found the sound to be quite muffled, no body, and with the volume turned right up there was hardly a trickle of sound coming out, but all in all it was an interesting excersise.
The 40watt PA output transformer however does work quite well with the 16ohm speaker connected to the 4ohm output to achieve the 8k primary impedance, I have no hesitation in recommending this setup for anyone seeking to try it.
again, thanks heaps for all your input in this thread!!
cheers Ron
Old 18th July 2013, 07:33 AM   #12
Good outcome Ron,
I've got several 6BM8's in the box that will need an OPT some day. I'll keep in mind the need for more than 5 watts.
I'm currently bread boarding some 6AM5 tubes thro a 5 watter, loosely following the Trainwreck schematic.
I found 20 of the 6AM5's when packing for our move from Melbourne to Hawkes Bay - they were in a box under a layer of some other obscure tubes I had been given
Maybe I should move countries more often?
Cheers
JimG
Crossover impedances grendal Multi-Way 4 1st January 2012 06:12 AM
EAR 509 OPT Impedances Unimog Tubes / Valves 0 13th November 2011 02:40 AM
More impedances for Hammond 125E revintage Tubes / Valves 1 25th August 2009 02:40 PM
Matching Impedances dscrobe Tubes / Valves 3 26th September 2007 06:49 AM
Speaker impedances Vivek Everything Else 11 30th July 2001 08:07 PM
Copyright 1999-2017 diyAudio
