Marshall Plexi Clone - Page 3 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 25th June 2013, 02:02 PM   #21
Renioo is offline Renioo  Poland
I got the reply and there is propably something with Us being too low. It is taken from half of Ua = 280V. There is something wrong I think with diode you can see on board. The Ua is made OK but after the diode for Us there is only 115V. I attach the photo.
The diode I think is russian D226
Old 25th June 2013, 03:17 PM   #22
It was the diode... I found out what is D226 and replaced it with 1n4007... voltage back to 420 on screen and works perfectly... I have a set of new tubes then... good
Old 25th June 2013, 04:29 PM   #23
Struth is offline Struth  Canada
Banned
Hi Guys
Vs sets the range for Vg1, so now that Vs=420V, you will need about -42V on the control grid as a minimum to keep the tubes under control. Before plugging in output tubes, assure that the bias range encompasses this value, and preferably can sweep to about -50 or -60 to assure full control over the tube.
Have fun
Kevin O'Connor
Old 25th June 2013, 04:57 PM   #24
So everything is set nearly allright. I can adjust it up to -40V with this pot (somehow strange). I will measure mV going from pin 8 with 1R.
Old 25th June 2013, 05:07 PM   #25
Banned
Hi Guys
Modify the bias supply to provide greater negative sweep BEFORE plugging power tubes in.
Otherwise, it is your choice to waste your tubes.
Have fun
Kevin O'Connor
Old 25th June 2013, 05:17 PM   #26
Will do.
Old Marshall plexi clone problem w437776 Instruments and Amps 0 1st February 2012 09:08 PM
Marshall 1987 Plexi HT Voltages kgc-jr Instruments and Amps 5 5th March 2011 01:06 AM
Building Marshall Plexi zxx123 Instruments and Amps 1 19th June 2004 04:01 PM
Building a Marshall Plexi edsmith Instruments and Amps 10 18th May 2004 06:38 AM
Extra gain stage Marshall plexi 50watt edsmith Instruments and Amps 1 22nd March 2004 05:58 PM
Copyright 1999-2017 diyAudio
