**** me, I bought the wrong box. - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 8th June 2013, 03:41 AM   #11
I've been able to fit these into a 1590A before, so you should be able to make it fit without the battery. Probably have to offset the jacks.
You could probably point-to-point wire it. Use the DC jack, footswitch, and volume control as tie points.
Old 8th June 2013, 02:58 PM   #12
Cassiel is offline Cassiel  Libya
I will fit everything inside but not with the jacks I had. Standard jacks no good for this box. Too wide. Using special ones.You will see. I think it will be finished today.
Old 10th June 2013, 12:46 AM   #13
Default I have a dilemma.
I have decided to use an external battery pack. I think it gives me more freedom and I don't have to worry about hum issues. My dilemma is the following: six Ni-Cad 1.2V batteries (2400 mAh) in series gives me 8 volts, I know it should be less but that's what I'm reading. It goes to more than 11 volts with eight batteries in series. I'd prefer six as the battery pack would be lighter. What would you do, iaxxaxxai? Is this circuit very sensitive to over/undervoltage?
* Seven would be ideal, I know, but due to the way I'm doing it, it's got to be six or 8.
Old 10th June 2013, 12:52 AM   #14
This is what I'm talking about. Of course it would have longer leads.
Ni-MH Battery Pack
Old 10th June 2013, 01:03 AM   #15
It should work fine on 8v. You can adjust the bias if you need to.
I have actually built a pedal with an external rechargeable battery before. It was a pack of six cells. I don't remember the voltages it produced, it's been awhile.
You could use a standard 5,1mm barrel connector for the battery pack so the pedal could use either the batteries or an external supply. And then you could potentially use the batteries to power other pedals as well.
Old 10th June 2013, 01:09 AM   #16
Great. It's six then.
Yes, that's a good idea. I thought about that. Thanks for everything. The circuit is finished but I haven't had the time to finish the box.
Old 10th June 2013, 01:11 AM   #17
wait, I just found a pic of it... it was 8 cells and put out 9,6v
Old 10th June 2013, 01:15 AM   #18
Funny, I just read the voltage - it's going down after the recharge. Probably it will stay on 7.2 volts. I think that would be too low. 8 cells then?
Old 10th June 2013, 01:19 AM   #19
Here are pics. Also found a pic of that very small one I built awhile ago. It looks like there's extra stuff in the circuit for this one. Pretty sure I built it with one of those charge pump chips to make a negative supply. I don't do that anymore. LOL
Old 10th June 2013, 01:20 AM   #20
here's inside the small one...
I bought a box of old valves, some new in box and I want to build some projects hofnergalaxie Instruments and Amps 13 27th May 2013 03:19 PM
What am I doing wrong in this box calc.??? CLS500 Multi-Way 39 7th August 2012 06:57 PM
Wrong Voltage / current on BoZ... or Wrong Measuring ? gionag Pass Labs 8 14th May 2008 11:24 AM
Just bought a few heatsinks..... Jan Dupont Parts 4 21st September 2005 01:23 PM
Copyright 1999-2017 diyAudio
