Bias voltage problem - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 22nd May 2013, 08:17 PM   #1
scrimpu is offline scrimpu  United States
Default Bias voltage problem
I just got this amp from a Thomas organ and while checking voltages I found that I have no voltage on the bias line. The schematic shows I should have -15v but my meter reads 0. I have only turned it on for a short time but it did seem to work ok while it was on. I did have the 25vac but I get +35vdc on the + side of C702 but 0 on the other end when it should be -15. What would cause this?
Old 22nd May 2013, 09:34 PM   #2
Where are you taking your measurements with reference to? Where is the black (neg) probe sitting when you are taking your DC measurements?
Also, did you check all the transformer coils for the proper voltages?
Let us know and we can go from there.
Old 22nd May 2013, 10:19 PM   #3
Voltages are pretty much normally except that I don't have any negative voltage in the bias circuit. Its reads 0v from ground to any point from the grid resistors to R702. Schematic shows I should have -15v there.
Old 22nd May 2013, 11:01 PM   #4
Where does pin 1 and 2 go? (this might be important to why we are not seeing -15V)
It appears they are to bypass that 1M resistor or have some input into that line you are trying to measure.
Also do you get the correct labeled voltages around V7028?
Old 23rd May 2013, 01:13 AM   #5
I don't have the organ so I don't know where pins 1 and 2 went. I assume it went to some sort of tremolo control. After reading voltage again I am about 100v short on the B+ rail and I have 18v not 30v at pin 8 of V702B and still 0v on the bias rail.
Old 23rd May 2013, 03:10 AM   #6
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
That bias supply is unconventional (polite way of calling it weird).
They are trying to make 1 circuit do 2 jobs ... in a way that having trouble on one causes *big* problems in the other..
Bad engineering.
Main question is: will you use this in the original organ, as intended ?
In that case, connect the missing part and everything should go back to normal.
Yet, as I said, having a design that when you disconnect the preamp it kills the power tubes isn't my idea of reliability.
The 25+25VAC winding + diodes SD701 make a DC supply with unloaded voltage of 35V DC.
It's a *floating* voltage, not directly referenced to ground.
Now, if you ground it through R701 and connect the other end to some "mystery" point which sits at +15V , which "eats" 107mA, and voltage drops to 30V DC, then one end of C702 will also sit at +15V and necessarily the lower end will be at -15V.
A very "iffy" design, depending on a delicate balancing act to work at all.
Personally I would disconnect C107 "+" end from connector S701 pin 2, would ground it through another 140 ohm 5W resistor, so as to have a balanced and symmetrical load (basically I'm replacing the mystery elements at the other end of the connector) , now I will have the proper -15V bias and call it a day.
Good luck and post results.
Old 23rd May 2013, 04:45 AM   #7
I have never even seen the organ it came from and cant find any useful info it so the mystery parts remain a mystery. I had planned on using it as a guitar amp and usually would just gut the thing but I am curious to see how it sounds with the original tremolo and 6GK6 tubes. When I read voltages with tubes I get about 265 B+, with only the recto I am getting 420v B+, is that normal? It seems like quite a big difference. I don't see a C107, do you mean C702?
Old 23rd May 2013, 05:37 AM   #8
I installed the 140R and all voltages are right on. Now how can I can the tremolo to work again? Something was connected at S701 pin 1 and 4 but I don't know what. I also am not able to get a voltage reading at pin 8 of V702B, the schematic shows 30v there.
Old 23rd May 2013, 08:34 AM   #9
Enzo is offline Enzo  United States
The trem doesn't work? get the oscillator running, it appears to be free-running. Zero volts on pin 8 or the tube? OK what is on pin 6. Says 300v, but if it is really high, then the tube is not conducting. Are both sides of that tube heaters running? it is a simple circuit, you opught to be able to solve that part. Then we need to get the interface running. I SUSPECT that the lines going off the page merely short across R711. That then allows the oscillator signal to couple to your bias feed via C703.
Old 23rd May 2013, 09:04 AM   #10
Bad engineering.
I would completely agree - but the OP's problem is that the amp can't be used 'stand alone' as the bias voltage is dependent on whatever is connected to pin 2, and how much current it takes.
Easiest option would be to redesign the bias circuit sensibly, adding a small mains transformer, rectifier etc. and a preset to adjust the bias.
Nigel Goodwin
Exceeding bias voltage? rntlee Tubes / Valves 15 3rd May 2012 09:57 AM
Driver Bias and Voltage? SGregory Tubelab 1 3rd January 2010 10:24 PM
Bias Voltage AmpBuilder225 Tubes / Valves 4 17th March 2009 11:27 AM
Bias problem- 1 Socket shows extremely low bias! otokomae Tubes / Valves 12 31st December 2008 10:01 PM
bias voltage vs bias current woodturner-fran Tubes / Valves 3 24th February 2007 11:24 PM
Copyright 1999-2017 diyAudio
