Bass pre-amp DI output - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 14th May 2013, 03:02 AM   #11
Not just a transformer, but a DI transformer and a big coupling capacitor should be OK.
The DI transformer doesn't want to see any DC from a single-ended tube. The 1/2 Alembic is single-ended class A so it has DC that gets blocked by a cap in its output or the next stage input at the power amp. Single-ended output transformers are special things with air gaps and large cores to cope with the DC. So Jensen really wants you to provide a push-pull driver ideally, otherwise I guess you drive the transformer thru a large isolation capacitor so you don't lose bass. No need for another transformer for your normal high-impedance output. I would recommend a volume for each output, with a pull-switch range pad on the DI volume pot. A pull-switch on the main high impedance output to mute to a high-impedance dummy load might be convenient if you want to hear just the DI. The DI should have a ground lift, and if you plan to use it for monitors you want a DPDT polarity-reverse switch on the DI output too. Neutrik makes nice jacks that take an XLR, TRS balanced 1/4, or TS unbalanced 1/4, and the transformer will work balanced or unbalanced, so that's a nice jack to use and you can shove in just about anything. The load impedances should be much higher than the source impedances, so you shouldn't have trouble with the 2 volumes interacting as long as neither load is ridiculously capacitive or inductive, and they shouldn't ever be.
But get the opinion of a real EE on-list, not just me.
Old 14th May 2013, 03:29 AM   #12
diybass is offline diybass  New Zealand
So the big coupling capacitor would connect to pin 1 of the 12ax7, then to the tranny, then other end of tranny primary to ground? What does the circuit for a volume control and pad look like for the DI out? Nice idea to have a phase reversal switch!
And what should I use for the dummy load for the high z output? Is a dummy load necessary for a preamp? I thought it was just for tube power amps?
What exact tranny anyway?
Sorry if some of my questions sound stupid, but I'm still fairly new to this. Having a heap of fun learning though!
Expensive transformer for bass DI? kkurosawa Instruments and Amps 12 28th November 2012 07:22 PM
Acoustic Guitar Pre/Comp/EQ/Blender/DI Josh Duke Analog Line Level 9 26th May 2012 11:49 AM
Impedance matching for DI to Mic Pre Fezzle Instruments and Amps 67 27th February 2012 10:32 PM
Impedance matching for DI to Mic Pre Fezzle Solid State 1 10th February 2012 07:13 PM
Help needed with direct output (DI) for bass amp funk1980 Instruments and Amps 11 3rd February 2012 10:53 PM
Copyright 1999-2017 diyAudio
