Stuck on Circuit Guitar Preamp LED mirror - Page 4 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 2nd June 2013, 08:39 PM   #31
Mooly's Avatar
The input impedance is high at around 1meg. I don't know what the output from a guitar pickup is but if you need more gain then you can drop the value of the two 5K6 resistors. And try the gain option on the final opamp.
Possible improvements. Using TL071 or TL081 opamps for opamp 1 and 2. The hf response of the 741 will be poor at such high gain but that doesn't matter to much since the guitar fundamentals are quite low.
Use high efficiency LED's and tweak the final resistors to get desired brightness.
Installing and using LTspice IV. From beginner to advanced.
Old 3rd June 2013, 06:11 AM   #32
Default Thank you Mooly
Wow Mooly, I am really excited to try it out and see if I can get it to work. Thank you so much for taking the time and energy (and brainpower) to put this together for me. Let me know if there is a way I can return the favor. swissCHEESER
Old 3rd June 2013, 07:16 AM   #33
Mooly's Avatar
Your welcome
Old 3rd June 2013, 08:35 AM   #34
Zero D is offline Zero D  United Kingdom
@ Mooly
Hi, i simmed your latest circuit & i'm pleased to say it definately seems to work fine, after a little tinkering. So congrats on that
The 2k7 resistors failed to light up the virtual LED's, so i swapped them for 270 Ohms, which did the trick. You did mention though using HB LED's, & they wouldn't need such a low value.
@ swissCHEESER
Hope you get it working
Old 3rd June 2013, 08:58 AM   #35
Mooly's Avatar
Never heard of virtual LED's before True high brightness LED's can be to bright to comfortably look at even with just a few milliamps.
Old 14th June 2013, 09:14 AM   #36
Hey Mooly, I had to order some parts and find the time to build the circuit you designed. Just finished - It works marvelously well! Thanks a million! What an amazing effort by you -- I really appreciate it. Sincerely, swissCHEESER
Old 14th June 2013, 09:18 AM   #37
Mooly's Avatar
Your welcome. Pleased its what you wanted
Old 11th September 2015, 06:03 PM   #38
Default Thanks again Mooly
Hey Mooly,
Just wanted to let you know the circuit is still in use and I still really appreciate the effort you put in to design it. I never could have done it without your help. I am about to build another one just like the first. Looking forward to putting it together.
Many thanks,
swissCHEESER
Old 11th September 2015, 06:08 PM   #39
Mooly's Avatar
That's great Pleased to hear that its all working OK.
Simple Mirror Type PreAmp with Low Distortion circuitscc Vendor's Bazaar 3 21st December 2010 04:59 AM
Need confirmation on LED bias for circuit phrarod Tubes / Valves 56 10th May 2010 03:03 PM
no current mirror, current mirror, cascoded current mirror, bjt or jfet VAS? maxpou Solid State 31 17th June 2008 05:31 PM
Looking for a LED voltmeter circuit DolbyR Equipment & Tools 9 9th May 2006 08:31 AM
Tube preamp with current mirror Tyimo Tubes / Valves 19 1st May 2006 08:05 AM
Copyright 1999-2017 diyAudio
