Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 7th May 2013, 02:24 PM   #1
Default Biasing for single supply to op amp
I'm struggling with a biasing arrangement for an audio preamp I'm building.
The circuit has to be run off a 9v battery and also requires a high input impedance.
I'm using an op amp for the impedance buffer, so have created Vcc/2 for virtual ground.
The problem is that the DC operating point is not right at the +input of the op amp - it's at c.0.95V from a supply of 8.72V and VRef of 4.15V. I have attached the circuit. All other points are working at the DC op point I expected.
I'm almost 100% sure that this problem is something to do with the high value of R3. I have altered the values for R1 and R2 to compensate for the value of R3 and can get a bit closer to Vcc/2 but in order to get there properly I would need to increase R1 / R2 by a lot. This is a problem, especially as this is an audio circuit, in terms of Johnson noise contribution it would make.
So, I was wondering if anyone had any ideas on how to get around this?
I was thinking about using a rail splitter op amp like the TLE2426, but I don't know if this would make any difference when faced by such a high R3 value. I have already tried buffering the voltage divider and that didn't help...
Any thoughts much appreciated.
Old 7th May 2013, 04:02 PM   #2
Loudthud's Avatar
According to the schematic you posted, R3 is 100 ohms. That's a very low value. You might want to make C2 10 times the value of C3 so that low frequencies do not modulate the Vcc/2 voltage.
Old 7th May 2013, 06:14 PM   #3
DF96 is offline DF96  England
The very low value for R3 will not affect DC very much, but it could do unwanted things to AC signals.
My guess is that you have not actually built what you think you have built i.e. you have a wiring error or a faulty component.
Old 7th May 2013, 06:41 PM   #4
Mooly's Avatar
Try this. The input impedance is around 50K (that's not high ) and is the value of R1 and R2 in parallel.
You can go as high as you want with R1 and R2. Even up to 10 Meg ohms or even far higher still if you can guarantee no external leakage or conduction paths.
C3 could usefully be lower in value, particularly if you use higher value resistors. Make sure you have the polarity correct.
Pin 3 has to be at one half Vcc using equal value resistors. If it is not the opamp is faulty or incorrectly wired. However... remember your meter loads the circuit too and if its a low ohms/volt type then that would pull the apparent voltage down on those resistors. If the opamp output is at 4.5 volts then pin 3 should be at an identical voltage too.
Don't worry over noise at this stage. And remember you probably need a cap at the output too.
A simulation free zone. Design it, build it, test it.
Old 7th May 2013, 07:31 PM   #5
Thanks for the replies everyone. The R3 100 ohm value was a mistake - it should have been 10 Meg ohms! I was messing around with the simulator and forgot to change the value back before posting - schoolboy error...
The problem did indeed turn out to be the multimeter I was using pulling the voltage down - I connected an LED at op amp Vout and probed the +Vin of op amp and the LED went out...
Turns out there is nothing wrong with the circuit.
The input coupling cap will be smaller in the final version - just put it in there as that value for the time being. Will also add an output cap as well.
Thanks again guys.
Old 8th May 2013, 06:10 AM   #6
Mooly's Avatar
Thanks for the update
Connecting Multiple op amp inputs from a single op amp output ZLyzen Analog Line Level 7 8th August 2012 12:17 PM
Wanted: Op-amp with single supply, 32V or more, and rail-rail capability akis Power Supplies 3 13th November 2010 01:53 PM
Op amp class A biasing. pro Solid State 33 2nd December 2004 11:20 AM
Recommedation for op amp for single supply applic? leadbelly Solid State 3 15th March 2004 09:01 PM
TDA3875 and TDA3886 and TDA 4780 Single Supply Biasing abid_rehan Chip Amps 3 28th February 2004 04:21 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
