Amp for electric violin / cello. - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 22nd April 2013, 08:00 PM   #11
Send a message via MSN to DoomPixie
im not completely set in stone on the 50C5's, i have other choices just thought it would be nice to experiment with them. This will only be a small practice amp though, it will be a combo with an 8" speaker.
As for size of the room, I currently use SET EL84 amp in my hifi and it is more than loud enough. A friend brought round one of those little marshall 1W amps with the 12AU7 PP output stage for her to try out and even that was uncomfortably loud with the violin running through it.
Old 9th August 2014, 08:37 PM   #12
Kastor L's Avatar
Send a message via ICQ to Kastor L
Any simple DIY violin amplifier around you can make with op-amp's?
SKY reference
Old 9th August 2014, 08:48 PM   #13
You can only make preamps with opamps, although you can use them in the front end of some power amps (but it seems fairly pointless to do so).
Nigel Goodwin
Old 9th August 2014, 09:04 PM   #14
Kastor L's Avatar
Originally Posted by Nigel Goodwin View Post
You can only make pre-amp's with op-amp's ///
Y?
SKY reference
Old 10th August 2014, 01:36 AM   #15
mcgruff is offline mcgruff  United Kingdom
How much clean headroom do you want, and how loud do you want to be when you hit overdrive? A 5F1 Champ - or 5F2A with tone control - might be all you need. Choose an efficient speaker if you're more interested in clean volume.
Old 15th August 2014, 09:14 PM   #16
for the same amount of money you'd spend building one, you can purchase this one:
http://www.carvinguitars.com/products/AG100D
check out the specs. pretty impressive.
very flexible and can be used in a variety of situations. comes in different colors as well if that matters.
HLLY T-Amp 90 good on violin and vocal?? fatboysan Vendor's Bazaar 0 22nd February 2011 05:16 PM
electric violin - headphones amplifier Amber19 Instruments and Amps 6 20th January 2011 01:14 PM
When Is a Violin Like An Amp? destroyer X Instruments and Amps 20 25th April 2010 07:22 PM
What to build - Electric Violin Combo Amp? error401 Instruments and Amps 7 5th September 2008 10:30 PM
Need advice with making an electric violin... :) SkinnyBoy Instruments and Amps 35 21st November 2004 07:16 AM
Copyright 1999-2017 diyAudio
