Modified Alembic F2-B - Page 4 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 16th May 2013, 01:46 AM   #31
That's very interesting; I assume that's the power transformer for the preamp? What are the secondaries' voltages and currents?
When I build the Trace Elliot V8 I intend to put it on two chassis: preamp and power amp. And I want the preamp to have its own power supply, so that the stock power transformer on the power amp power supply can handle the extra heater current (at the least) of switching from 8 KT88's to 8 KT120's. But the V8 has 7 dual-triode preamp tubes and 1 driver, then the 8 outputs. So would one of these preamp power transformers suffice, or would I need two?
I have some other big bass guitar amps I might make similar changes to, basically adding a seperate power supply just for the preamp.
Old 16th May 2013, 01:53 AM   #32
Stormrider's Avatar
Send a message via AIM to Stormrider Send a message via MSN to Stormrider
The 6K27VF is rated 120VAC 15mA DC and 6.3VAC 600mA. It's only good for two low current dual triodes.
AJ
Old 17th May 2013, 03:53 AM   #33
Oh well I'll have to actually look around & shop.
Improving upon the Alembic preamp ClydeWilliam Instruments and Amps 5 29th January 2013 05:59 PM
Alembic F2-B phil mailloux Instruments and Amps 101 12th October 2011 03:07 PM
Alembic F2-B project gone cookoo Nordskov Instruments and Amps 3 17th June 2009 09:03 PM
Pre/PS ala Alembic croat47 Instruments and Amps 3 16th March 2006 02:50 PM
Alembic F-2B mbonus Instruments and Amps 3 3rd March 2006 05:55 PM
Copyright 1999-2017 diyAudio
