Fender reverb circuit diagnostics/repair - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 3rd April 2013, 04:33 PM   #11
cancon is offline cancon  Canada
Thanks again, that's interesting.
The old pan is 4EC3C1B. I think you're right - this was a wrong replacement. I learned a lot from these two links:
accutronics_products_and_specifications
spring_reverb_tanks_explained_and_compared
So the important details from the code translate to Type 4 length (17"), 600ohm input impedance, 10k output impedance.
Delving further into the reverb domain... I notice (more often than not) that reverb circuits are noisy, commonly adding lots of hiss as you bring up the control knob. I did a quick test, unplugging the pan input did not reduce the hiss, but removing the output did...so would the pan or recovery stage be suspect?
Old 4th April 2013, 12:02 AM   #12
Enzo is offline Enzo  United States
Hiss is a companion to gain. The reverb recovery deals with weak signals and so has a lot of gain. That can be noisy. You can unplug the reverb cables from th baack of the amp and listen to the hiss from the circuit itself. The long wires down to the pan will pick up noise. They are shielded, but that is not 100% efective. Also, the footswitch for reverb is simple, it grounds the return signal. The reverb footswitch is a shielded cable, parallel the pan output, and in the foot pedal it simply shorts teh shield to teh signal. So unplugging the footswitch potentially reduces noise. Anothewr factor, the metal reverb pan has an open side. One might get some improvement by putting a metal cover over the open side.
Clone a Fender Vibrolux Reverb? kpatt99 Instruments and Amps 8 29th August 2012 09:55 PM
Fender 6G15 Reverb Question bluezrider Parts 1 21st February 2009 08:00 AM
Fender twin Reverb theriffa Instruments and Amps 1 11th May 2008 03:15 PM
Fender super twin reverb jazz Instruments and Amps 1 4th September 2007 09:30 PM
Good old Fender Twin Reverb Netlist Instruments and Amps 9 14th January 2004 02:55 AM
Copyright 1999-2017 diyAudio
