Peavey Renown 400 Issues - Page 5 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 21st February 2013, 06:08 AM   #41
Enzo is online now Enzo  United States
CR6, CR7 are clamps, just as CR13, CR14 at the input stage, and CR25, CR26 at the power amp input. They don't do anything under normal conditions. But in the case of large signals or unwanted voltage on those jacks, they shunt anything beyond the 15v rail voltages, which would have the net effect of LOOKING like reverse voltage to the IC. You don't want voltage on your IC that exceeds its power rails. These clamp diodes are quite common onb PV circuits, especially their mixers.
Old 21st February 2013, 11:58 PM   #42
Send a message via AIM to ouimetnick Send a message via Skype™ to ouimetnick
Well I took some readings, so here we go.
U1 Pin 1: 7mV
U1 Pin 7: 19mV
U4 Pin 1: 2.5mV
U4 Pin 7: 1.3mV
U5 Pin 1: -3.3mV
U5 Pin 7: 1.6mV
U6 Pin 1: 6.8mV
U6 Pin 7: 29mV
U7 Pin 1: 9.6mV
U7 Pin 7: 9.8V YES, volts, NOT mV
U8 Pin 1: 1.7mV
U8 Pin 7: 3.9mV
U9 Pin 1: 6.8mV
U9 Pin 7: 6.5mV
DC Offset with preamp disconnected: 10mV
DC Offset with preamp connected: 10mV
DC Offset from the preamplifier: -9.7mV
U1: TL082CP
U4: TL082CP
U5: TL082CP
U6: RC4558P
U7: RC4558P
U8: TL082CP
U9: TL082CP
Old 22nd February 2013, 12:08 AM   #43
That would be the reverb driver opamp U7b.
Do you have the reverb unit plugged in?
What are the voltages on pins 5&6 of that chip?
That is high,disconnect the reverb if it is not and see if your noise goes away.
jer
Old 22nd February 2013, 12:10 AM   #44
jer
This is with the reverb disconnected.
Old 22nd February 2013, 12:15 AM   #45
jer
U7 Pin 5: 18.7mV
U7 Pin 6: 19.4mV
Little correction.. I said that the amp was dead silent with the preamp disconnected. Well, not completely true. If you put your ear to the speaker and listen carefully you can hear the hum very faintly, and hear the scratchy sound. The hum and scratching is a bit louder with the preamp connected.
I'm starting to suspect it may be the filter caps in the preamp section.. I know that when filter caps are failing, you get a but of a hum.
The scratchy noise sounds like a dirty pot or like I'm brushing the preamps output to the input on the power amp. A scratchy static noise. As stated, all pots were cleaned and have no effect (well the lead gain post knob lowers the hum when it is set to the 12:00 position, but not by much.) All jacks were replaced, and even when directly soldering the preamp to the power amp, the hum and scratchy noise still remains. All jacks are properly grounded, and all board solder joints were reflowed.
Old 22nd February 2013, 12:29 AM   #46
Okay it could be be high becuase it is disconnencted.
I would have to model that circuit in Circuitmaker (spice) to be sure as pins 5 and 6 appear to be normal.
I would tear mine apart to check as well but I don't have the room at the moment.
If you reconnect the reverb unit it may return to normal as it has a lower resistance than the 4.7k resistor that you are measuring across but I still think it should be close to 0V any how.
Did the reverb work?
Don't connect it yet though.
jer
Old 22nd February 2013, 12:30 AM   #47
Reverb works great. I just didn't want to unscrew it from the cab.
Should I just pull U7 and see what happens, or is U7 needed to keep everything happy? In some amps (like Hafler) removing the MOSFETs cause the voltage to shift wildly and burn resistors, so they need to stay in to keep it working.
Old 22nd February 2013, 12:35 AM   #48
Okay good then U7b is working then.
Is the hum still there when the reverb volume is off?
jer
Old 22nd February 2013, 12:37 AM   #49
Hum doesn't change regardless of any control change (except the post gain in the lead channel quiets the hum ever so slightly when set to 12:00 position.)
Old 22nd February 2013, 12:42 AM   #50
I just read post 45.
You can check and see what your ripple voltages are by measuring the supply rails with your meter set in AC voltage mode.
jer
Peavey Renown Solo Series? Ninesvnsicks Instruments and Amps 9 20th January 2012 09:06 AM
Peavey CS-400 Schematics Wanted Zero Cool Instruments and Amps 31 8th August 2009 08:43 PM
Peavey 400 blowing fuse on power up Barnacle Instruments and Amps 11 2nd February 2009 10:49 AM
Copyright 1999-2017 diyAudio
