| Instruments and Amps Everything that makes music, Especially including instrument amps. |
#11 | |
and you have load resistors mounted on input ? have to say, you need someone better than me, sorry did you check valvewizard's website ? |
#12 |
I did check out Valve Wizard. I downloaded Ch.1 of the preamp book and found it really helpful. I just ordered both books.
Among other things I learned that the plate resistance is *not* in series with the other resistor like I figured up above... |
#13 |
#14 |
if you want to roll of highs you could try 1M grid stoppers before the 12ax7s
#15 |
I'm starting to understand all this- it's really very exciting. And empowering!
Thanks all. |
| Removing Tone Controls from VoM Preamp/Amp | RevMen | Tubes / Valves | 5 | 19th May 2013 04:49 PM |
| Guitar EL84 push-pull, tone control placement | getonemaker | Instruments and Amps | 8 | 12th August 2012 03:24 AM |
| a portable headphone amp with bass and treble tone controls | xilw3r | Headphone Systems | 1 | 22nd June 2012 11:06 AM |
| modify parallel push-pull EL84 to single push-pull | chungtat | Tubes / Valves | 12 | 3rd November 2005 11:25 PM |
| Double push-pull versus single push-pull | jraraujo | Tubes / Valves | 19 | 19th October 2002 12:23 AM |
