long tailed power amp class a - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 6th February 2013, 09:34 PM   #11
cheers bud did the cap and switch mod loving the sound!!!
since my first project is done now, cab pending, i think it's time i put pen to paper for no.2. does anyone have any advice on the design process, this is my first attempt at a PI let alone a power amp that does it. for example to elevate the heater voltage can i just do the usual and connect heater c.t. to cathode (around 100v)?
one last q, in long tail PI's the inverted output usually needs a lower load to to achieve the same gain as non inverted? do you reckon using ul taps might help sort this? if no one has a clue i'll give both a go and post results as i have a similar tx with ct at 45%
Old 7th February 2013, 12:40 AM   #12
Is there some reason you want to do the circuit dropping so much across the 'tail'? The tubes you have are not really high output. What is the point?
Old 7th February 2013, 01:29 AM   #13
i was under the impression more Volts across tail meant better balance? also i think i mentioned earlier i am delibarately after low output power and high input sensitivity.
however if you think 250v, 100v for tail and 150v for anode would be too low i can provide 350v, 100v tail and 250v anode.
Old 7th February 2013, 04:02 AM   #14
I think 50V would be more than enough and 250V supply might give you 5W out. I do not care for amps with less power but you might. You still have not said what your target is only low power.
Old 7th February 2013, 05:34 AM   #15
Originally Posted by akadazzle View Post
same sorta goals i had to be honest, what sort of output power should i be aiming for? i was thinking maybe around 6-8w would be a safe max as these are rated for 7w peak in se or do you think i could push a little more? as i mentioned these cores look uncannily like the one from an lc15 so maybe i might get lucky with 10w?
i don't know what power to aim for, i think anything above 2W would suffice for this 1, i can always beef it up a it after i finished
Degeneration resistors in long tailed pair 2KW Solid State 4 9th July 2012 02:06 PM
long tailed pair - need more gain hidnplayr Tubes / Valves 37 21st October 2010 08:52 AM
Voltage Gain on Long Tailed Drivers lassoharp Tubes / Valves 7 24th May 2010 03:41 AM
Long tailed pair schematic questions martyh Tubes / Valves 17 28th January 2009 10:27 PM
Long Tailed Pair Modification lubbie Solid State 31 11th May 2004 07:11 AM
Copyright 1999-2017 diyAudio
