diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Instruments and Amps (http://www.diyaudio.com/forums/instruments-and-amps/)
-   -   speaker wiring (http://www.diyaudio.com/forums/instruments-and-amps/228681-speaker-wiring.html)
epirich 26th January 2013 02:09 PM
speaker wiring
new to these forums, I could seem to find a section that this question fits in, I was wondering if anyone knows how they wire a 4 speaker guitar amp cabinet to come up with a 8 ohm load? 2 pairs of 8's in parallel then those 2 pair in series?
Enzo 26th January 2013 02:31 PM
Yes, exactly, assuming the four speakers are each 8 ohms.
The wiring is in fact called series-parallel wiring. It allows four driviers to have the same impedance as one driver.
epirich 26th January 2013 11:36 PM
Thanks Enzo ! , I was just always under the impression that you dont use series wiring on speaker setups to often
Speedskater 27th January 2013 04:03 PM
As long as all the speakers are the exact same model, series wiring is not a problem.
ArcticBreaze 27th January 2013 11:40 PM
series is always safer than parallel where speakers are at least close to the same wattage as ohms my go too low.
Resources saved on this page: MySQL 18.75%
