Voltage Regulation (LDR Related) - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 13th January 2013, 05:01 AM   #1
Default Voltage Regulation (LDR Related)
Hi. My friend talked me into building a guitar amp, while I was immersed in a robotic auditory microphone array of my own. With each investigation conducted, my interest has grown all the more.
I decided to go with a tube pre and SS power section. After scouring through countless articles and schematics, I found this interesting circuit for the Soldano SLO.
The question is, what exactly are VR1 and VR2? Those parts of the circuit are mentioned in the commentary (second link), but it is unclear to me. I do not know if there is a regulation circuit somewhere, or the LED is just symbolic of what the writer is talking about.
It is first mentioned here: The Third Stage
Any comments would be appreciated.
Thank you.
Old 13th January 2013, 05:31 AM   #2
astouffer's Avatar
The leds are housed along with a cadmium cell that changes resistance with the amount of light. Good for isolation or a simple way to control resistance by some other means.
Old 13th January 2013, 05:47 AM   #3
Thanks. I was afraid of that. Well, it's either try to get the circuit from "sloclone", use a Fender pre, devise my own controls, or otherwise redesign the circuit.
Old 13th January 2013, 06:29 AM   #4
astouffer's Avatar
You can always wire in a pot of the same value and adjust it manually. What controls the leds?
Old 13th January 2013, 06:45 AM   #5
Yes, I am a big fan of slider pots in prototypes. But my knowledge of tube amps is almost non-existent, and why reinvent one of his spokes?
"The AC load consists of a 2.2M resistor in parallel with a 330k resistor and the output impedance Zo of the normal channel's second stage." This is vague.
Perhaps somehow the referred to impedence is translated to the isolator? The amp, in its entirety has been built, and I saw the optos in some pics. Finding info on that site is not fun.
It's coincidental that I already had the idea of using some kind of electronic control with digipots and/or audio switches and a PIC. But this design requires these particular optos in order for the circuit to work.
Old 13th January 2013, 07:38 AM   #6
Default Found it...
Just need the component specs. I should also find out what the switches do.
The information is scattered and buried.
Old 13th January 2013, 02:49 PM   #7
kevinkr's Avatar
Since this is clearly related to guitar amps I have moved it to the proper forum. Please make note of the sub-headers in each forum category to determine whether or not you are posting in the right place. Thank you.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 13th January 2013, 11:53 PM   #8
VR1 & 2 are used to switch the overdrive circuit in and out of circuit. When the footswitch is pressed, it lights up the led's in the VR1 & 2.
Old 14th January 2013, 10:37 PM   #9
Enzo is offline Enzo  United States
The two LDRs - VR1,2 - have a high resistance when dark, and they go to a low resistance when lit up by the LEDs. One of them thus shunts the signal to ground when lit, while the other completes a signal path in the other channel. The two LEDs are probably wired in series to operate together. So when they are darl, that one shunt disappears, and the signal path above opens. SO light or dark alternates channels. YOu could replace them with a pair of relay contacts, I suppose.
Old 14th January 2013, 11:02 PM   #10
Thanks. When I checked the price of those LDRs, I sought an alternative. I found essentially the same circuit that uses relays. This is better for me since they can be easily replaced with digital switches, if desired, somewhere down the line. Plus the circuit is easier for me to understand.
But I am not given the HV output number. I have seen several lead amp designs ranging from 300-480v., which I find shocking. What the heck, here it is. Maybe someone could ballpark it.
Zeners and voltage regulation WILD1 Tubes / Valves 88 21st March 2012 05:08 AM
Mains voltage regulation jerryo Power Supplies 18 31st December 2009 09:08 AM
Voltage regulation for TL494? thunderpld Power Supplies 0 14th March 2009 10:28 PM
Thyratron voltage regulation rcavictim Tubes / Valves 2 2nd March 2007 09:25 AM
Voltage Regulation from a battery bigphil Power Supplies 9 14th October 2006 03:44 PM
Copyright 1999-2017 diyAudio
