Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 14th January 2013, 09:35 PM   #31
hmmm.... wondering if i wanted the arduino pin HIGH signal to unmute the audio, wouldn't it make sense to connect the audio input signal to pin 3 of the NJM2521, rather than pin1?
that way an arduino LOW signal would mute the inpute, HIGH would let it flow through... amirite?
Old 14th January 2013, 11:45 PM   #32
hope that post before last doesnt go unnoticed..
Old 15th January 2013, 12:43 AM   #33
I think your concern it is valid but remember the first thing you should do when you initialize the micro it is immediately set the I/O pins outputs to their start up conditions.
Old 17th January 2013, 10:38 PM   #34
i got the chips from fedex today - for some reason this setup is NOT WORKING
any thoughts on what i might be doing wrong?
Old 17th January 2013, 11:29 PM   #35
Enzo is offline Enzo  United States
I didn't read back through the thread, so sorry if I missed something. But looking at your drawing, I see you are using input #2. And the logic for selecting input 2 involves SW1 being logic HI and SW2 being logic LOW. Your drawing shows no connection at all to SW2. Connect SW2 to ground, and then bringing SW1 hi with your module ought to select input 2 to the output.
Old 17th January 2013, 11:35 PM   #36
I agreed with Enzo. If you let the input floating internally it is high.
cs3318 and arduino linuxworks Analog Line Level 72 26th March 2013 11:56 PM
LM1876 Mute by Voltage divider. pra3718 Chip Amps 26 9th December 2012 01:41 PM
LM1876 Mute & Stand-by pra3718 Chip Amps 14 23rd November 2012 02:59 PM
need LM1876 mute mode and standby mode help JozzaG Chip Amps 21 19th January 2012 05:28 PM
please help - no mute but did mute mod - tda1541 loomis Digital Source 1 14th November 2002 10:54 AM
Copyright ©1999-2013 diyAudio
