| Instruments and Amps Everything that makes music, Especially including instrument amps. |
#11 |
hey tauro
im worried the mute pin might draw to much power from the arduino. the I/O pins of the arduino are limited to 40mA / 20mA reccommended! and for some reason i cannot get the mute pin to work anyway, using a 5v battery to mute pins and ground. weird huh? plus i need a latency free mute switch, and im not sure if the LM1876 mute pin works instantly... does anyone have experience with this chips feature? |
#12 |
If you check the mute in the schematic Figure 6. LM1876 you can see that the mute goes to the base of a transistor so it would not required a lots current to enable or disable the mute using the output from the Arduino. I will use the output with no problem. |
#13 |
Fast muting/ unmuting will cause pops.. there must be a better way to get where you need to be .. Unfortunatley we do not know what that is so it makes it a little difficult to suggest any other potential options ..
Regards Mark |
#14 |
Just to let you know that I am using a NANO micro to control the speakers output and also the mute of my LM3886 amplifier. Since the mute in the LM3886 it is negative and for isolation I am using a solid state relay LH1546. It worked with no noisy whatsoever.Just clean in the ON/OFF. |
#15 |
hey, thanks for all the replies!
maybe i can switch the signal on/off before the LM1876 - if i where to use this IC :: http://semicon.njr.co.jp/eng/PDF/NJM2521_E.pdf can someone help me draw a schematic that flips a low power signal on/off with my arduinos digital pins? thanks, úlfur |
#16 |
Audio Junkie
try a 10k resistor between the arduino and the LM chips. that should sufficiently limit the current.
you could always use some small signal transistors as switches connected to the arduino to mute the chips. plenty of examples on the arduino web forums for that!
It's not about what you can BUY...It's about what you can BUILD! |
#17 |
#18 |
Attached is an schematic on to do the input selection switching. This is an idea how to do it. It use 2 I/O pins from the Arduino micro. |
#19 |
#20 |
At the beginning I was unable to follow the circuit since you over look that pin 1 it is the one with the square. You have to turn around the socket or leaving it like it is just cosmetic. Are you trying to switch audio no? I was thinking that you was trying to mute the LM1876. The NJM2521 what it does is to select one output from three inputs. I just want to verify that were are in the same track. |
| cs3318 and arduino | linuxworks | Analog Line Level | 72 | 26th March 2013 11:56 PM |
| LM1876 Mute by Voltage divider. | pra3718 | Chip Amps | 26 | 9th December 2012 01:41 PM |
| LM1876 Mute & Stand-by | pra3718 | Chip Amps | 14 | 23rd November 2012 02:59 PM |
| need LM1876 mute mode and standby mode help | JozzaG | Chip Amps | 21 | 19th January 2012 05:28 PM |
| please help - no mute but did mute mod - tda1541 | loomis | Digital Source | 1 | 14th November 2002 10:54 AM |
