diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Instruments and Amps (http://www.diyaudio.com/forums/instruments-amps/)
-   -   Speaker question (http://www.diyaudio.com/forums/instruments-amps/227393-speaker-question.html)
MARIUS2 9th January 2013 01:29 PM
Speaker question
Can i run 2 speakers left output 400 watt and the same amp 2 speakers right output 140 watt - adjusting the potentiometers to suit output - in other words the amp output will be totally unbalanced
firechief 9th January 2013 02:00 PM
What kind of amp? Brand and model.
KatieandDad 9th January 2013 02:17 PM
It matters not an iota what each channel is doing. In true stereo one channel may have a thunderous noise being produced with the other channel being fairly quiet.
It'll sound horrible and unbalanced but there is no reason why you can't run a stereo amplifer as two separate amplifiers.
Indeed if you simply unplug one of the inputs to a stereo amplifer, that is exactly what you would be doing.
MARIUS2 9th January 2013 02:22 PM
The amp is Fane FDJ450 - i will be playing in mono because it is for sound re-enforcement in a hall
Thanks for the reply
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
