Hybrid amp design - Page 7 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 9th January 2013, 03:15 AM   #61
Originally Posted by Robert Kesh View Post
CC, am curious about your biasing. What voltages show on the cathodes and grids??
Good point.
If we make R3 & R6 100k, then we get 0V on the grids with the cathode @ 0.7V and the anode @ ~21V with 0.375mA quiescent, (kind of conventional) but surprisingly with the values shown, the anode moves to ~4V with the cathode and grid @ ~-7.8V, the cathode actually being slightly (about 0.1V) more negative than the grid, the quiescent current goes to ~0.8mA, but the output waveform (when hard driven), while still pretty square, is considerably more symmetrical than with the 100k's (because there's more room to swing positive I guess). When lightly driven, both look quite clean. There's plenty of gain (>35 after both stages) and the FFT looks pretty typical for a tube.
It all kind of blew me away, but I'm not really a tube guy, and I just have to go with the sim. Of course I could be operating it wrong, or there could be problems with the models.
Looking at it again, I'd probably put a blocking cap at the input, it's not hi-fi.
Perhaps you'd care to comment further, as I said, I'm not really a tube guy, I'm just old, old, old.
Old 9th January 2013, 05:23 AM   #62
m145mcc is offline m145mcc  United States
You do have some valid points. I did remove the 1M resistor, It did make little since after you pointed it out.(pertaining to previous post) I did include a grid stopper (R8, R9, C4), It forms a roll-off at about 4khz. I got rid of the gain at (R4,R2) because it didn't seem like a good idea to load the next stage with 30 volts, but If I can do that without damaging anything I'll remove (R4, R3) and replace with a proper grid stopper. Just to make sure I got my lingo right, a grid stopper is to filter the DC from the signal right? (R10, R11) was to drop everything down to about line level, the pot was just for level control. I do appreciate your provided schematic, but I would hate to just copy your work.
Old 9th January 2013, 09:59 AM   #63
Robert Kesh's Avatar
Originally Posted by counter culture View Post
Good point.
Thanks. Some models aren't good at modelling grid current, which obviously sky rockets when the grid is close to positive.
Old 9th January 2013, 06:48 PM   #64
That's the spirit, make your own mistakes.
A grid-stopper is a series resistor placed as close as you can get it to the grid pin on the tube, often ~10k, but the value can actually be calculated to work best with the dynamic input capacitance of the tube.
Grid Stopper Resistor Calculator
Old 11th January 2013, 04:08 AM   #65
Pretty sure I have everything buttoned up now. The frequency response looks good. Hopefully someone can approve this. I still got to add supply caps and a few other little things, oh and thanks for the grid stopper link.
Old 11th January 2013, 09:21 PM   #66
Looks fine.
Old 11th January 2013, 09:26 PM   #67
Your not yanking my chain right? Thanks, ill post a few pics after I build this thing. Thanks for every ones help.
Old 11th January 2013, 09:47 PM   #68
No, looks like totally standard two stage design. Even got the standard grid stoppers.
I guess you may want to be prepared to tweak the output divider to match whatever chip amp circuit you use. And remember you'll need a coupling cap after the output.
If it's of interest, I just built a tube chip amp hybrid myself, just got it working today, but in pieces and bread boards, etc. Two 6N11s and an LM3875.
Old 11th January 2013, 10:15 PM   #69
very cool, and I probably will tweak the "attenuator". you should post a few pics when ya get every thing done. I would be very interested to see and maybe hear it.
Old 11th January 2013, 11:54 PM   #70
Since everybody been so helpful I was wondering if anybody has an psu advice. I using a Avel Y236652 250VA 25V+25V Toroidal Transformer 122-625 and a 262F6 Hammond Manufacturing | 262F6-ND | DigiKey . I'm 65% sure this will give me what I need With "ok" ripple rejection. I'm most worried about the way I'm going to wire the tube filaments. sorry no neat simulations just pen and graph paper this time.
Hybrid tube headphone amp design ashok Headphone Systems 21 30th December 2012 06:17 PM
any suggestions for a mid-amp transformer for a hybrid design... like this circuit... bassetrox Tubes / Valves 9 5th October 2011 09:47 AM
Hybrid Amplifier Design Luck Chip Amps 32 3rd March 2009 03:43 AM
Question about a hybrid PSU design reaction Tubes / Valves 2 11th October 2004 12:45 AM
Copyright 1999-2017 diyAudio
