Hybrid amp design - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 1st January 2013, 07:50 PM   #11
doozerdave's Avatar
I would suggest that the high voltage op-amp might be better suited in stage 2. From my experience, the real beauty of tube guitar amps is the feel of the input going right into the grid of a tube, so I would like to see a triode in stage 1. You should be able to have enough headroom at +/-40V with that op-amp to fully saturate the next triode stage (stage 3) without over-driving the op-amp.
As for 12VAC on the heaters, you really should have them at 12.6VAC (or 6.3VAC with them in parallel). There is a serious tube life derating if you run the heaters too low, far worse than if you run them a bit too high. You can get small, cheap heater transformers like these ones Hammond Mfg. - Power Transformer - Economical Single Primary - (166 Series)
-Dave
Old 1st January 2013, 09:19 PM   #12
Robert Kesh's Avatar
Originally Posted by m145mcc View Post
Nope, both triodes are at about 150 vdc.
I mean that 47K, R18. That effectively raises the lowest voltage the anode can swing to by about 50V.
Old 1st January 2013, 09:38 PM   #13
m145mcc is offline m145mcc  United States
Sir Robert I don't want to sound to needy, but would you by chance happen to have a link on the analytical analysis of a simple triode config. Dozerdave I will rework that tonight and try to post an updated revision. I'm realy glad I decided to join the forum you guys have a lot to offer.
Old 1st January 2013, 09:48 PM   #14
The Valve Wizard
Old 1st January 2013, 10:51 PM   #15
That's perfect, thanks
Old 2nd January 2013, 12:47 AM   #16
No prob. When you've digested that, go to his homepage and check out the rest of his articles. The one on the DC coupled cathode follower is important, you see it in pretty much every tube amp, is responsible for a good part of tube sound, and is easy to implement in a pre amp.
How to design valve guitar amplifiers
Old 2nd January 2013, 01:24 PM   #17
I made a few very minor changes, I ran a frequency response analysis on it and a wave form analysis. I think I'm going to build it when income tax rolls in. If anybody sees anything like seriously wrong with it let me know.
Old 2nd January 2013, 08:59 PM   #18
You should use the OPA453, as that's the equivalent optimised for high gains like yours.
Old 2nd January 2013, 09:30 PM   #19
Ya know I was just thinking of switching op-amps too, what do you think about the LME49710?
Old 2nd January 2013, 09:34 PM   #20
I take that back I'm preferring the OPA453 now that I look at it, loads of gain!
Hybrid tube headphone amp design ashok Headphone Systems 21 30th December 2012 05:17 PM
any suggestions for a mid-amp transformer for a hybrid design... like this circuit... bassetrox Tubes / Valves 9 5th October 2011 08:47 AM
Hybrid Amplifier Design Luck Chip Amps 32 3rd March 2009 02:43 AM
Question about a hybrid PSU design reaction Tubes / Valves 2 10th October 2004 11:45 PM
Copyright 1999-2017 diyAudio
