Running up tube heads - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 29th December 2012, 02:38 AM   #11
Hi
All good stuff, thanks.
It won't be 10 years between power-ups, but it could be a while before he uses it again in anger. It's in a house in California, not a storage locker (which I might have implied) so I don't think damp will be a problem, but I will mention it.
Although he doesn't have his Marshall cab with him, I'll just hook up an old 8" 8-Ohm speaker to a 1/4-inch plug and send it to him so he can at least shut off the standby and have a load on the output. I know most SS amps have open circuit protection, but I wasn't sure about tube heads.
Phil
Old 30th December 2012, 05:22 AM   #12
I'll send him a li'l old 8-Ohm 6.5-inch so heas something to plug in and turn off the standby
Phil
Old 30th December 2012, 10:52 PM   #13
Banned
very slowly induce lower voltages/current/power is a great idea variac is a great tool
Old 31st December 2012, 03:12 AM   #14
Hi
In principle a Variac is fine, but it's only been three months since it was being used regularly, so I don't think there is much worry turning it on.
Phil
Old 31st December 2012, 05:27 AM   #15
Banned
probably not with only 3 months
Old 31st December 2012, 05:28 AM   #16
Banned
I thought like he was talking about years lol
Old 2nd January 2013, 02:33 AM   #17
ivan H is offline ivan H  Australia
Hi, yes it definitely needs a speaker or suitable dummy load hooked to the output to power it up, (not in standby). With regard to the filter caps, on another guitar amp forum they give the following instructions for forming new, or reforming electrolytics in amps. Disconnect the rectifier from the filters & hook it back up with a 100k, 2 watt resistor between the rectifier & filter caps, then power it up, periodically checking the voltage drop across the resistor. When the voltage drop across it is below a few volts the caps are formed. Drain the caps properly & remove the resistor, hook back up the way it was. This is current limiting the caps while forming them, whereas using a variac is only voltage limiting. Hope this helps. Cheers
Old 2nd January 2013, 03:58 AM   #18
Ummmm...no. I am not putting my hands in a tube head for any reason. No sir. Besides, it's 3000 miles away, and I only really wanted to know about firing it up every few months. I'll be surprised if it's more than a year before he is back in a band again.
Phil
Heads up for Australian tube amp diyers Bibliophile Tubes / Valves 1 9th June 2012 11:19 AM
here is one for the rare tube heads...6GY8, 6EZ8 aletheian Instruments and Amps 11 27th July 2011 09:30 AM
Trinity Tube Heads AriesMotor Vendor's Bazaar 0 14th November 2008 05:11 AM
Any tube-heads in Scotland? martinab2 Tubes / Valves 2 1st February 2005 10:31 AM
About tube tape recorder heads walk Tubes / Valves 10 28th September 2002 10:22 PM
Copyright ©1999-2017 diyAudio
