Fender FM212R Problems - Page 26 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 20th February 2013, 01:44 AM   #251
badraven's Avatar
Location: The heart of the South, in other words -Redneck Territory lol
Well I will change the caps as soon as they come in.
When you say it sounds like the bias is at fault. I assume you mean because I had to double the resistance of R95 and 96? That cuts the current doesn't it? Or do I have that backwards?
As for the fans, mine are marked 12v I don't have any experience with venting amps. Will these run off the +16v rail or so I have to mock up a circuit to cut the voltage? Or better yes, is it better to create such a circuit? And will wiring two in series cause enough of a V drop to accomplish this?
If at first you dont succeed, perhaps it isn't your bag. Lol...
Old 20th February 2013, 01:51 AM   #252
nigelwright7557's Avatar
Yes increasing the resistance decreases the bias current.
16 volts is a bit much for a 12 volt fan, put a resistor in series. Something like 22r 7 watt.
You would need 24 volts if you put two fans in series.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Old 20th February 2013, 09:19 AM   #253
Originally Posted by badraven View Post
Anyway I ohmed the old cap and its shorted. So I guess its no wonder the outputs were running hot.
I should check C39 as well - C40 on it's own shouldn't cause any ill effects, as it's referenced to ground on both sides.
Nigel Goodwin
Old 21st February 2013, 12:45 AM   #254
badraven's Avatar
Smile Nigel Goodwin
Nigel
I'm ordering caps for the amp. C40 may not be the whole problem but things sure changed dramatically when I changed it.
Old 21st February 2013, 12:54 AM   #255
badraven's Avatar
Default Nigel
It is great playing my amp again!!!
Originally Posted by nigelwright7557 View Post
Unless the amp case has lots of large vents then for a power amp you definitely need a fan or two.
I use pc cases for my amps and have 2 fans at opposite corners, one sucks air in while the other blows it out the opposite corner.
When you say PC Cases are you talking about a PC power supply to power the fans?
It sounds like your bias is at fault for the overheating problem. You need to find the setup procedure for the amp.
A simple approach would be to play a sine wave through the amp and look for crossover distortion on a scope. I was surprised just how little bias you can get away with.
However quite a few people prefer the sound if the bias is run a bit hot.
How do I get the Setup Procedure for my amp? From Fender? If so, they will give this info to non-dealers?
Do you have a suggestion for creating the sine wave you are talking about? Of course I don't have access to a scope for maybe it doesn't matter at this point.
Old 21st February 2013, 06:01 AM   #256
Enzo is offline Enzo  United States
There is no "setup procedure", after all there are no adjustments. Fender publishes the schematic, and that is all there is. it is expected any service tech can do what is necessary to check for bias being appropriate and take whatever measures might be required. Ther is no procedural manual. Sorry.
It will be very hard to look for a crossover notch in the waveform without a scope.
Is the overheating happening while the heat sink is bolted to the chassis? Or is the board off the chassis at the time? The board must be mounted to chassis to provide proper cooling.
Q14,15 are thye bias transistors, I forget, are they stock types? And have any of the diodes been substituted? D30,D31 are schottky types, having a low forward voltage drop. Putting a "regular" diode in their place would warm the amp up.
Old 21st February 2013, 08:16 AM   #257
badraven's Avatar
Default Enzo
That's what I was thinking but I didn't want to contradict.
The "primary" heatsink where the outputs are mounted and the thick aluminum block/spacer that goes between the chassis and the mounting for the transistors is what I had for a heat ballast until I mounted everything back in the case the other night. I had clamped a pair of locking pliers on the heatsink to add to the ballast capacity of the sink. The heating problem pretty much went away when I replaced C40.
Last night and the night before I sat here and played the amp for several hours with no problems that I know of.
Q15 was replaced with a KSA1013 I installed a TIP31C at Q14 because that's the only NPN I had with the correct pinout. When my order arrives I will swap in the correct transistor.
I have not changed D30 or 31. Not sure how to test them yet.
Old 21st February 2013, 08:35 AM   #258
chris661's Avatar
Its easy enough to hear if pure tones are being played.
I actually rather liked the sound of my amp (when it was working) with a little crossover distortion going on.
Old 21st February 2013, 11:05 PM   #259
That may be, and I agree, a little crossover does no harm, but our original poster here has no signal generator and asked earlier how to come up with test tones.
Old 21st February 2013, 11:11 PM   #260
Badraven, if I counter someone else's stratement, it is not done out of disrespect, it is a point of information, hopefully useful information. We all have things we are used to having, but not all situations comply with those expectations. I sure as heck have made faulty assumptions in trying to post things in forums like this, and unless someone points out my error, it won't be corrected. SO if something seems wrong or you don't understand, say so.
Fender help Docc25 Instruments and Amps 3 2nd January 2013 10:18 PM
1970s fender champ givin me problems beauxweiss Instruments and Amps 4 21st February 2012 04:53 PM
MiniWatt N3 problems, oscillation thumping and RF/motor problems. Destroyer OS Tubes / Valves 18 6th July 2010 12:14 AM
Fender Adjustments JDeV Instruments and Amps 6 7th April 2006 08:17 PM
Another Fender on the bench. Netlist Instruments and Amps 3 6th March 2004 08:03 AM
Copyright 1999-2017 diyAudio
