| Instruments and Amps Everything that makes music, Especially including instrument amps. |
#201 |
Location: The heart of the South, in other words -Redneck Territory lol
I got that part. Its understanding what I am reading on the screen that I am asking about.
Master Po: You must take pebble from hand. Grasshopper: Give me the damn thing NOW! |
#202 |
It will display a number from 1 to n.
You will need to look up your transistors spec to see what typical Hfe is.
http://www.murtonpikesystems.co.uk PCBCAD50 pcb design software. |
#203 |
I just put a 2N4403 PNP transistor in the meter.
40V 600mA 625 mW Shows 269 on the meter. What is that telling me?
#204 |
The DC gain of the transistor is 269.
Sounds good to me but check your transistor spec to be certain. The spec usually has a range of possible values like 40-100.
#205 |
I am attaching the datasheet. Can you tell me how to read this so it makes sense to me?
#206 | |
269 looks good to me as the upper limit is 300.
#207 |
So Current at the Collector of 150mA should produce 100 to 300 hfe, correct?
#208 |
Yes.
#209 |
Now if I were checking a transistor with the same specs as this transistor and I got a reading of say 310 or higher that could well be the problem or part of the problem.
#210 |
It would be unusual for it to be that high.
Usually if there is a problem you will get a low figure like 1 which probably means there is a short in the transistor.
| Fender help | Docc25 | Instruments and Amps | 3 | 2nd January 2013 10:18 PM |
| 1970s fender champ givin me problems | beauxweiss | Instruments and Amps | 4 | 21st February 2012 04:53 PM |
| MiniWatt N3 problems, oscillation thumping and RF/motor problems. | Destroyer OS. | Tubes / Valves | 18 | 6th July 2010 12:14 AM |
| Fender Adjustments | JDeV | Tubes / Valves | 6 | 7th April 2006 08:17 PM |
| Another Fender on the bench. | Netlist | Tubes / Valves | 3 | 6th March 2004 08:03 AM |
