Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 21st December 2012, 09:05 AM   #11
tinitus is offline tinitus  Europe
how about adding some form of integrated but mild and moderate compression and distortion control ?
Old 21st December 2012, 10:11 AM   #12
GeorgK is offline GeorgK  Austria
Originally Posted by artosalo View Post
The anode (to cathode) voltage is some 120 V, because there is R5 (22k) as cathode resistor. This means that the DC-voltage at the cathode is some 130 V.
Won't this exceed the maximum filament to cathode potential?
The idea with 2 levels of feedback is interesting, but isn't that potentially counterproductive in a SE guitar amp that is likely to be driven out of its linear range? Guess only listening can tell.
Old 21st December 2012, 10:21 AM   #13
artosalo's Avatar
I do not know this.
Can you give an example of such circuit ?
Now the pentode goes distorted when the signal form guitar is at maximum.
And the distortion threshold can be adjusted to lower level by biasing the pentode a bit different way.
Old 21st December 2012, 10:31 AM   #14
artosalo's Avatar
The manufacturer has specified max. Ukh as +120 V...-150V.
Typically there is a lot of safety margin too. I am not concerned about this.
No, these two feedback loops are working fine together and both improve the linearity, alone and together.
I have used this system with Hifi-amplifiers and it seems to work with guitar amplifier as well.
If only the global NFB is used, then the overall stability of the amplifier could be a problem in some cases. In other words; the use of local NFB at the output tube makes a "good" amplifier easier to build.
Old 22nd December 2012, 08:26 AM   #15
I do not know this.
a while ago I found this passive compressor curcuit
I dont know if its any good
distortion control I guess is only a matter of overdriving one gain stage
and I suppose it means one more attenuation pot
one to cranck up the gain, and one more after the overdriven tube, to attenuate it again
hmm, and maybe additional adjustment pot or switch, to bring the overdriven tube in a state where its easily overdriven
Old 22nd December 2012, 01:22 PM   #16
@tinitus: this is a simple diode limiter, I doubt this is of much use in a guitar amp.
Old 22nd December 2012, 06:54 PM   #17
its probably not the most effective
but being less effective may not be a bad thing at all
anyway, its said that all compressors have flaws
but I guess we have to test it to know
Old 24th December 2012, 05:32 AM   #18
hi Arto, is this a country fellow man to you ?
Guitar Effects Projects - Richardo's Pages
and theres is a lttle bit here too
http://www.261.gr/limiters.html
dont if if its of any use to you
Old 24th December 2012, 05:48 AM   #19
artosalo's Avatar
Yes, he seems to be.
Old 29th December 2012, 01:09 PM   #20
I do not know this.
hey, found a sweet word for you....bass fuzzcaster
EL509 as a CF GK Tubes / Valves 1 9th May 2008 09:25 AM
el509/519 horn150 Swap Meet 2 20th September 2007 08:48 PM
EL509 vs EL519 resident Tubes / Valves 3 15th November 2004 02:01 PM
Rewiring that EL509 cadman Tubes / Valves 1 12th November 2003 05:49 PM
SE amp with EL509/6KG6A (help) NotInTheMafia Tubes / Valves 1 10th December 2002 07:51 PM
Copyright ©1999-2013 diyAudio
