Project: Simple bass guitar headphone monitor mixer - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 18th February 2013, 05:56 PM   #11
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
some suggest to bootstrap the jfet buffer ?
(don't know if it makes sense)
can I ask...what is the 1M from drain(power) to base(input) doing ?
I know other curcuits use it, but is it needed with these jfets ?
Old 18th February 2013, 06:20 PM   #12
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
In this case (split supply) it's not needed.
Its function is to raise the Source voltage (by raising the gate voltage) in single supply circuits, to raise the input signal handling.
Bootstrapping?
Maybe, if you want to raise input impedance.
Not really needed here, because 1M from Gate to ground is fine.
Old 18th February 2013, 06:27 PM   #13
No it doesn't, pretty pointless with an FET.
Again, seems pretty pointless, just the single resistor to ground is all that's required - and it could be increased to increase input impedance, meaning there's no need for bootstrapping (which is what you'd do with a bipolar input in order to give a higher input impedance).
Nigel Goodwin
Old 18th February 2013, 06:50 PM   #14
I don't know about bootstrapping, but the two 1M resistors between ground and V+ create a reference voltage. The V+ to base resistor wouldn't be needed in a dual supply configuration (I could also skip it and connect the base to ground resistor to the opamp's voltage divider).
Good info about fet-buffers: Basic Buffers
Old 18th February 2013, 07:02 PM   #15
Isn't a vref bias better than ground? It might be pointless in this case, but that's beyond my knowledge. I've made buffers like this before and they've worked fine, so I didn't see any point in modifying the circuit.
That buffer is actually the thing I'm the least unsure of about this design.
EDIT: Just noticed a typo in the schematic, the 3k3 source resistor should of course go to ground, there's no negative supply in the design anymore (but the 1M resistors still stand).
Old 18th February 2013, 08:00 PM   #16
It just seems a waste of a resistor?, you're wanting a negative bias on the gate - achieved by the voltage drop across the source resistor - biasing the gate positive doesn't seem a very good idea?.
It's not something you normally see used commercially.
Try taking the top resistor out, and see if you can tell any difference
According to the webpage you linked it's supposed to improve large signal handling, but it could just as well make it worse
Either way shouldn't make a great deal of difference.
Nigel Goodwin
Old 18th February 2013, 08:17 PM   #17
JMFahey's Avatar
Sorry but it's very much used commercially.
And the point is, as I said before, to improve input signal handling.
Another important point is to make biasing and signal symmetry more predictable, without time wasting individual tweaking or obsessive Fet matching.
DIYers, of course, add a so called "biasing" preset to every Fet stage
Old 18th February 2013, 08:47 PM   #18
The impact of the existance or removal of this resistor goes a bit beyond my scope, but I have another question:
Since this amp is going to be used live on stage, it would be very nice to have some kind of limiter so that I don't become deaf when the singer drops his microphone, or when the sound guy accidentally bumps the monitor feed.
One way to achieve this seems to be using a diode clipper. (A collection of circuits here: Designing A Limiter For Headphone Amplifiers | HeadWize)
Is this a good idea? One obvious problem is the difference in efficiency amonst headphones, it would clip too early on some and too late on others if the clipper is placed at the output, right?. If it's placed at the input, it would work only relative to the input signal, not in absolute terms.
I'm open for suggestions here, but the design cannot be anything too fancy, because I need the design to fit in a small enclosure.
Old 20th February 2013, 08:57 PM   #19
don't know
but mighty glad I finally got the compressor out of my bass system
Old 27th February 2013, 08:10 AM   #20
I would reconsider using the LM386 for a headphone amp, it's a total crap house IMHO.
Why not either go for LME49600/ BUF634 or an opamp stage with follower transistors (for instance BC327/BC337, or BD139/BD140 if you need more clout)?
Oemptempa petoempetapap
Bass Guitar Headphone Amp? jman 31 Headphone Systems 44 3rd December 2013 10:14 PM
ESP Project 94A, What am I doing wrong? (Simple Mixer) audiomodder Analog Line Level 1 10th January 2010 08:47 PM
1x10" bass guitar monitor with variable port tuning and notch filter? alexclaber Multi-Way 7 1st April 2008 06:24 PM
Need help with my first project; 7x6 headphone/monitor/matrix mixer jumpfroggy Headphone Systems 5 10th January 2008 07:36 AM
Bass guitar headphone only amp oldhernace Headphone Systems 1 14th July 2005 04:33 AM
Copyright 1999-2017 diyAudio
