| Instruments and Amps Everything that makes music, Especially including instrument amps. |
Hi!
I'm building a bass preamp (not my first). I'm using a three band active baxandall tonestack found in the LF353 datasheet (I'm using OPA2134 however). If I'm not completely lost, this tonestack produces an inverted signal, and would need to be re-inverted. Right? So I plan to put an inverting gain stage after it, and then use the remaining opamp section as an output buffer. Does this seem at all sensible to you?
#2 |
Why bother?
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#3 |
#4 |
The signal will be inverted, no doubt, but it usually does not matter.
Even if you use a direct box, it will go to the PA, away from the stage. In fact many amps invert at random, sometimes even in the same amp (as in Fender Twins) where if you jumper both channels, you lose signal big way, because they go to the same power amp and speaker (not your case). And if you join many amps on stage, you'll typically chain drive them from your main preamp out to all other power amps, which *usually* (95% of them), are non inverting. But anyway we are talking about a single op amp stage, so go ahead if you wish, and add a "phase" switch, to select taking signal before or after it. Most PA and recording mixers have that available. It might be useful in some situation if, say, you drive 2 amps, straight at their inputs, from, say, some Bass effects processor. |
#5 |
Thanks for your replies! So basically it doesn't make any difference if I make the gain stage inverting or non-inverting? But if I have a separate gain stage, there's no harm in making the first section inverting like in my mockup, right?
#6 |
You have to be carefull in musical instrument amps when using non-inverting stages like the first stage in your schematic. If the input goes below about -12V, the output of that stage will slam the positive rail because the input common mode range has been exceeded. It's better to use an inverting stage there (noise may be higher), even better to add anti-parallel diodes at the summing junction to ground. This is why many opamp circuits have a reputation of sounding bad.
#7 |
#8 |
Yes, that would work but I would suggest that you make the input buffer inverting. Many modern bass amps use a variable gain stage as an input buffer between the bass guitar and any tone shaping circuits.
#9 |
#10 |
| sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 | jarthel | Chip Amps | 5 | 19th July 2007 12:37 PM |
| whats the difference between inverting and no inverting | mikee55 | Parts | 1 | 7th January 2007 10:36 PM |
| inverting / non-inverting op-amp circuits | Learnincurve | Solid State | 11 | 21st January 2005 05:40 PM |
| Bridged/Stereo, w or w/o servo, inverting 3886, inverting buffer PCB | Alexander Rice | Chip Amps | 9 | 27th March 2004 06:53 PM |
| Inverting/non-inverting Op-amp Inputs !!!help!!! | IIR | Solid State | 17 | 11th May 2002 02:02 AM |
