Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 14th November 2012, 02:31 PM   #1
Default 12FQ8 Guitar amp questions
I started putting together a guitar amp using some of the many 12fq8 tubes I scored from a wurlitzer organ the other day. I saw many articles where people used them to build a low voltage pedal but I thought with a 330v plate limit that it would be cool to put them to use closer to that spec. I have been useing 12ax7 type values for plate and cathode resistor with some success but found that their best performance is from paralleling all the plates (4 of them) together and useing each tube basically as one triode (grids paralleled also). I am no wizard at this stuff but not totaly dumb. Currently in that arrangement I am running 39k plate resistors and 1.5k cathode resistors. I have two gain stages seperated by a 1meg volume pot & coupling cap connected to a 12fq8 longtailed pair phase invertor useing basic fender resistor values. It is starting to sound cool but I am wondering if technicaly My plate and cathode resistors are close to correct. I do not have a full understanding of the math and theroy involved and hoping you guys could give me some guidence. The four plates throw me a curve ball. Thanks
Old 14th November 2012, 03:13 PM   #2
I wanted to add that I have about 275-300 volts on top of the plate resistors.
Old 14th November 2012, 03:26 PM   #3
well some of the other people already answered this in a different thread.
heres the chart:
and here is the thread:
12ax7 perfect bias point
Old 14th November 2012, 04:46 PM   #4
kevinkr's Avatar
Moved to Instruments & Amplifiers per forum policy
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 14th November 2012, 07:06 PM   #5
Well that's the chart for a 12ax7 not a 12fq8, also it does not address the two triodes and 2 plates parrelled, does it? was hoping to get a little more help. I started by using the rule of thumb that you double the plate resistance (76k) to get your plate resistor (152k), but all four plates are paralleled so I divided it by 4 (38k). But the data sheet says that the plate resistance is 76k if the other plate in that section is grounded. Not sure how that affects my factoring because it is not grounded. I am not confident at reading the chart so at this point I punted with my cathode resistor.
Old 15th November 2012, 04:51 AM   #6
I must have misunderstood, so all small signal stages 12fq8?
and why grounding the plate?
Old 15th November 2012, 01:21 PM   #7
12fq8 was a tube used in a Wurlitzer organ as a ossillator. there are like 28 of them in each organ. They are unique because they are a twin triode with four plates and a common cathode. their specs are somewhat similar spec-wise to a 12ax7. I was hoping to put them to use and see how they sounded in an audio circuit partialy because I am curious but also because I have 28 of them and I am cheap! also I couldn't find anywhere on the web where someone has done it. I found that using each triode seperately didn't seem to work. they seemed to ossilate with two different size signals going on so close to each other internaly so I decided to parallel them up. This is currently working. It was also my understanding that they were lower current tubes so I though this arrangment might help in that regard. As far as grounding the plate, that was in referance to a note on the data sheet talking about how the plate resistance is measured. 12FQ8 pdf, 12FQ8 description, 12FQ8 datasheets, 12FQ8 view ::: ALLDATASHEET :::
I'm having good results but would like to turn this project into a bigger learning expierience. Thanks, Fred
Old 20th November 2012, 08:49 PM   #8
I found this article the other day and it was very helpful. How to "Screw Around" Your Tube Load Line.
Looks like my guessing and reasoning has me in a good range.
Old 6th December 2012, 03:57 PM   #9
I have been having some success getting good tones form this amp but am finding that either I have twenty eight badly worn out tubes or they are not really suitable for the sensitive v1 position. Some of them have an excessive hiss, some buzz and some seem exceptionaly microphonic in the that spot, v2 and v3 seem okay. I either needed to rethink v1 or find some nos tubes and give them whirl. I made the tough desicion (not that tough, I am cheap) to replace v1 with a 12ax7, I took the opportunity to use both triodes of the 12ax7. The tone has become a bit more typical and less unique but still able to retain most of what I think may be the 12fq8 "sound". I will be submiting a schematic once I finish tweeking it.
Old 6th December 2012, 07:26 PM   #10
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Cool idea using them; I would also, if I had a small stash as you, but asking them to work well in the critical V1 position is a little bit too much
Although being as cheap as you, I'd first go from the input jack to a single Fet stage, or even a 10x gain TL072 or something (which would be "transparent", being far from overdrive) and only *then* continue to any old worn gassy tube I might be wanting to use.
Harmony guitar amp restoration questions Goldstache Tubes / Valves 1 20th April 2012 09:58 AM
Converting 12FQ8 for 12AX7 , HELP !!! DJDestiny Tubes / Valves 10 6th March 2011 05:20 PM
AB2 guitar amp design questions Craig405 Tubes / Valves 12 8th January 2008 06:01 PM
Bogen PA--->Guitar Amp, few questions Turbo7MN Tubes / Valves 100 5th April 2006 01:41 AM
EL84 Guitar amp questions (long, sorry) Sherman Tubes / Valves 2 6th September 2005 12:20 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
