effects loop, harp amp - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 15th October 2012, 02:12 PM   #11
Simon B is offline Simon B  United Kingdom
The OP's problem is feedback, and this looks like a clue to why it's happening:
Originally Posted by ArcticBreaze View Post
With the first triode turned turned way down about 2,3 and the second all the way up I can stand right in front of the amp putin out about 35 watts and no feed back..
But turn the primary Chanel up and the second down feedback city.
This is why i think an effects loop may help. get the pedals after the primary triode.
So maybe the first triode, or possibly the circuit immediately around it has a problem?
Have you tried swapping another valve into that position ArcticBreaze? I think that would worth trying. Certainly try tapping it gently with a rubber ended pencil to test for microphonics. If you get a note sounding like your feedback that would be a strong indicator to try some replacements, with whatever ECC802, ECC82, 12AU7 you can lay hands on.
Engineer: One who can do for 10 shillings what any fool can do for 10 pounds.
Old 16th October 2012, 12:58 AM   #12
ArcticBreaze's Avatar
No just using a modified guitar amp for harmonica.Its been the harp players curse For decades, put a mic into a guitar amp it sounds great till the guitarist drowns you out so ya turn it up a bit an it howls at you. (we don't do quiet lol)
After 2 years of tweaking, moding and annoying you good folks at DIY I can now turn up loud enough to be herd.
but there are limits, the more I raise the input gain the more sensitive the mic gets, by taking in a real low lvl signal and then boosting hell out of itI can get the sound lvl i want with out feedback (I don't know exactly why this works it was derived from sugestions in earlier thread here on diy and it worked) pedals tend to lift the gain going to the preamp or mayby stomp box's just dont like mic's and I cant afford a kendrik harp amp so moding my own (and learning a whole dmn lot in the process.) I've just about gone as far as i can with this amp it doesn't really fit in its case any more (new out put trany hits the speaker) so I'm going to build a whole new amp with plenty of room for a reverb tank, using the old amp as a prototype, its getten pretty messy in the with all the moding i,ve done (don't know why it doesn't hum).
But now I'm just waffling, thanks guys for all the help and suggestions past and future.
Fat Tubes For Fat Sounds
Old 16th October 2012, 01:58 AM   #13
Glad to hear that feedback is not a problem for you, just an opportunity to put in an effects loop.............
I want to put in an effects loop for foot pedals etc. but they cant go before the first stage of the preamp as this causes feed back on the mic.
an effects loop instead the spring reverb ? nadojaz Instruments and Amps 5 1st March 2012 03:07 PM
Valve effects loop eeka chu Tubes / Valves 6 16th October 2011 02:11 PM
Guitar amp effects loop finally done. jjman Instruments and Amps 0 21st March 2009 04:27 PM
effects of gain selector switch in the feedback loop? scone Chip Amps 13 4th March 2005 07:22 PM
Tube effects Loop Schematics... ? psychodave Tubes / Valves 0 23rd February 2005 07:40 AM
Copyright 1999-2017 diyAudio
