Crate Vintage Club 50 Problems - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 15th October 2012, 10:50 PM   #11
Enzo is offline Enzo  United States
The FX loop jack, is it just a single jack on this one? I suspect the cutout contact inside it is dirty or oxidized. Spray some cleaner in it and poke a plug in and out a few times. ANy help?
Reverb JFETs. Look at your schematic, the two JFETs which select which control sets the level are controlled by S and /S. They are opposite each other. The control circuit is by the Footswitch jack on page 1. The test points are called out, when one is at -10v, the other is at 0 volts. So you have a 1 meg resistor from each of those to each gate, and since the gates are shorted together. You wind up with 2 meg between S and /S. The gates are in th middle. SO when one is at -10, the other is at 0, ao the gates are in the middle at 5. Switch the other way, and the other end is no -10 and the opposirte end now is 0, so again you have 5. That is why your 9 makes 4.5 all the time. It is acting exactly as we would expect with those two gates shorted together.
crate vintage club 50 2x12 keeps blowing preamp tubes etwnpnks Instruments and Amps 1 13th January 2010 10:22 PM
crate vintage club problem slowrideee Instruments and Amps 10 7th October 2008 05:01 AM
crate vintage "club 50" schematics needed cbriere Instruments and Amps 2 14th November 2007 06:39 PM
Vintage Pionner Turntable PL-50 RockysDad Analogue Source 9 25th February 2007 11:21 PM
Crate DFX212 - Speaker problems mrrandylyon Solid State 2 27th October 2005 09:57 AM
Copyright 1999-2017 diyAudio
