picked up an old Fender amp - Page 10 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 13th January 2013, 04:38 AM   #91
Banned
An amazing clean machine I bet, I would be in heaven with a nice chorus pedal lol
Old 13th January 2013, 06:11 AM   #92
I measured the inductor. It's less than 7 ohms. 1.35 Henries. 1.1 amps. Teseted voltage: 1780. From Submarine Signal Co., Boston Mass. Probably meant to be used as ballast on a submarine; it's probably 20 pounds LOL.
That 7 ohms figure means a really minimal drop in B+ voltage from adding this choke. Simulation says RMS mighht only drops about 4 volts. That's incredible, and gets rid of almost all the ripple.
But the head is starting to weigh like an SVT.
Old 13th January 2013, 10:35 AM   #93
*imho* there's no need to filter all the current by such a bulky choke. Just filtering the screen and preamp supply current will do, due to the plate common mode rejection of the push-pull output stage.
Increasing the filter cap values is a good idea in an amp for the bass guitar. Just replace them by 470 F each. The original rectifier diodes supposedly will handle the inrush current, as even standard 1N4007's are rated for a peak surge current of 30 A.
Best regards!
Old 14th January 2013, 08:17 PM   #94
No doubt you're right; this is indeed very eccentric. It's the American in me: nothing exceeds like excess. If I hadn't made the cabinet extra-large it might not even fit. It certainly wouldn't be very portable for one person anymore, but it was never well balanced because one transformer was heavier than the other; I hope I can offset that weight imbalance and not make it any worse. The cabinet should really have handles at each end. Good thing I added aluminum base plates under the handle end mounts. At least I didn't pay new list price for the choke; the darn thing appears to have heavy cast ends too. It was probably intended for a base transmitter of some sort I would suspect. There's not a lot of selection available in these sizes of chokes, or I could have gotten away with a third less weight easily, though there are even larger ones on eBay. It will be a very interesting experiment; the weight is indeed the penalty. I will probably mount it so that it's easily removable with a plug and replaced with a small-value high-wattage wirewound resistor. I certainly could have gone farther to balance the push and pull sides to minimize the hum and then added a choke for the splitter.
There will be additional chokes further down the filter ladder for the lower-voltage taps.
Now I'm pricing new larger elctrolytic caps at Mouser and I'm shocked at the prices! There are cheaper caps, but not in stock. Perhaps someone can make some recommendations. Many have no ESR spec. Many are rated for 550V, which may be calling it close in a high-temperature 500v application.
And I'd also like to upgrade the rectifier to a modern 1-piece bridge unit that will handle the start-up current, mounted on a small heatsink of its own, mounted lower in cooler air and away from the tubes, instead of adding any heat to the chassis. And I'll probably put some ceramic disc caps right across the bridge, like the stock diodes had.
I don't really want to kill the power transformer either, trying to fill huge electrolytics and chokes at start-up.
I assume the capacitor values (220 stock main supply I think) in the schematic which are unlabelled are microfarad, not millifarad. I always find the mfd versus ufd for microfarad and Mfd for microfarad oddly inconsistent and confusing.
I think I'll also add some internal rail fuses.
Old 14th January 2013, 08:37 PM   #95
Yeah, I'm probably crazy for trying this on a 180-watt amp instead of a 50-watter first.
I don't think the stock diodes are in the selection drop-down list in the simulator. Then again, I doubt this simple simulator really simulates the effect of the duration of the current surge on the diodes realistically, it just tells you when the single 'spec' is exceeded.
I was modelling a 330 uF cap before the choke and another 330uf cap after the choke. That's using one 550v electrolytic at each point instead of two 260v caps in series like the stock config. Then, desipte the increased energy, I was hoping to use drain resistors with higher resistance, since they didn't also have to divide the voltage evenly across two caps in series anymore. I was hoping that might make up for a bit of the voltage lost across the new additional filter.
Old 14th January 2013, 08:57 PM   #96
At least I didn't try to find a 10 Henry inductor to add before the main rail line to the output trans center tap!
My first inclination was a much smaller 1/10 Henry between larger caps, but that didn't help much according to the simulator. Then again, this simulator doesn't show real-life garbage on the line, and the resolution of the view of the ripple just keeps getting better and better, but the ripple never blends into the background noise because there isn't any simulated signal or noise injected onto the line, just the 120 Hz from the rectifier.
I'm curious how much ripple from the stock supply gets cancelled in the stock output stage. Seems to me that's also voltage and current wasted, power ending up as heat in the output tubes just to make more heat in the output transformer. Perhaps reducing the cancellation occurring in the output transformer a bit might help it survive the additional power from the power supply upgrade. Then again, that's probably few watts and at these levels it takes many to make an audible increase in db volume.
Old 14th January 2013, 09:03 PM   #97
The capacitor multiplier idea somebody proposed for the second filter was very interesting, but I'm probably not quite ready for that yet.
I'd imagine using a capacitance multiplier circuit must affect the selection of the capacitor...wouldn't it have to drain & fill a lot more? Seems to me that's the heart of the matter, in a standard filter just a little ripple current and class B output current (and replenished from the trans/rect) flows in & out of the cap, but in a capacitance multiplier circuit a lot more current flows in & out of that cap when it's simlating a larger value.
Old 14th January 2013, 09:39 PM   #98
Cyclecamper,
do I understand you well that you fear to dissipate additional heat by cancelling ripple in the output stage? No way - this is done automatically by the tranny if the sums of all plate currents on each p-p side are equal! No heat ever produced by this! But you indeed will produce additional heat if you try to reduce ripple in the supply current flowing into the output tranny's center tap, more if you use an ohmic resistor (C-R-C filter), less for a choke (C-L-C), both for a given hum reduction rate. *imho* hum reduction will be sufficient, for not to say excellent, even in the original supply circuitry, if you provide a separate grid bias pot for each output tube, or at least for each p-p side.
Which are the prices of the electrolytoics you're looking for? Here in Germany those aren't that expensive, I think. If you do understand a little German, have a look here, e.g. We can buy electrolytics even cheaper from surplus here.
Another thing to mention :-): Induced by this thread I've been looking for such an amp on eBay. Indeed, a German guy offered one these days, calling € 850 (~$ 1120) - way too much. Of course he didn't sell it. At the end of the auction I offered him € 500 (~ $ 670). I'm still looking forward to his answer ;-).
Best regards!
Old 15th January 2013, 01:25 AM   #99
Hmm, let me think. OUch. I'll have to think more later. That just doesn't sound right. I would think B+ ripple current is turned into opposed currents at the two end taps of the output transformer primary, which the transformer primary winding resistance turns into heat. Of course it's not just resistance...lots of inductance there...and of course no output.
I see serviceable new high-voltage electrolytics for reasonable prices, but never in stock! Then ones that are in-stock for high prices. And none with complete specs.
I know of two Super Twins here in the US, one for $399 and another for $499. Definitely a bargain.
Old 15th January 2013, 02:01 AM   #100
I'd expect the filter to make as much or more heat, but NOT IN THE OUTPUT TRANSFORMER. I'd hope the B+ filter would make the output transformer run 1 degree cooler. I'm reaching and stretchign facts for justification LOL. Like the short professor espousing his "little bang" theory.
Just picked up an SMSL TDA7498 based amp ... to much hiss Tino Chip Amps 1 16th September 2012 02:37 PM
Fender 6L6 Amp... HELP!!! mjarve Instruments and Amps 18 28th November 2010 07:06 PM
Fender amp mitchelr Instruments and Amps 0 13th July 2010 09:41 AM
Fender Amp Trade? lpd Swap Meet 0 15th October 2008 02:02 AM
Just picked up an SAE P50 amp... Tino Solid State 2 9th February 2008 09:53 PM
Copyright 1999-2017 diyAudio
