| Instruments and Amps Everything that makes music, Especially including instrument amps. |
#11 |
Yea man Non-Residue Contact cleaner will be your best friend De-oxit, LPS etc.
#12 |
Hi Guys
Just as a clarification regarding pot cleaning sprays: DO NOT use WD-40 or similar water-displacement sprays that contain harsh solvents and grease. DO NOT use carburetor cleaners DO NOT use any spray designed for automotive use ONLY use sprays specifically designed for use on electronic components. BLUESTUFF is a thick pot lube and cleaner that is useful when there is open access to the pot resistive track. Thinner electronic cleaners can make thier way through seams in switch and pot cases, providing cleaning action but no lubrication. After applying the correct spray, rotate the pot from end to end a few times, or move the switch between its positions a few times. Go to broad-line electronics distributors such as Digikey, Mouser, Electrosonic, Newark, Farnell, Allied etc to find proper "electronics rated" chemicals. Have fun Kevin O'Connor londonpower.com |
#13 |
#14 |
Hell Yeah!
| Old Marshall plexi clone problem | w437776 | Tubes / Valves | 0 | 1st February 2012 08:08 PM |
| Building Marshall Plexi | zxx123 | Tubes / Valves | 1 | 19th June 2004 03:01 PM |
| 50watt Plexi Again | edsmith | Tubes / Valves | 2 | 23rd March 2004 07:14 PM |
| Plexi | WCC_Burnout | Multi-Way | 7 | 24th February 2003 05:22 PM |
