Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 11th September 2012, 05:39 PM   #1
SD456 is offline SD456  Hungary
Question DIY iRig
Hi all!
I want to build a DIY iRig, these lil' babies made by IK Multimedia and with the iRig cable or the iRig Stomp you can hook up your guitar to your iPad, iPhone or iPod Touch.
I think it could work with PCs too, so I want to build one, but I cannot find any schematics or gutshots on the web. If anyone have some sort of photo from the inside of an iRig or iRig Stomp, please share with me!
Thanks in advance!
Old 25th September 2012, 04:27 AM   #2
This is all what I have found. I hope can be useful!!
iRig.rar
Old 25th September 2012, 05:39 PM   #3
Peavey make a similar product, its just a 1/4" jack to 1/8" jack adapter to plug in a guitar and headphones.
To make one that plugs into the charging connector, you might need to make an app,
Old 13th October 2012, 12:42 PM   #4
I found a good guitar interface, it is very similar to the iRig but it is much, much cheaper.
I built it, and I'm using it for some days now, it is very good! No noise at all, well there is some noise when you crank a high gain amplifier in AmpliTube, but that's normal.
All the pots on my guitar is working as they should, and the sound of my guitar is cleaner, punchier.
If someone want to build it, here is the page
pre amp suggestions, DIY or Non DIY, Im easy mondogenerator Analog Line Level 5 20th August 2012 05:11 AM
DIY tube/phono pre in the same case as my DIY dac? ben62670 Analogue Source 3 29th October 2010 08:46 AM
diy disco lights? (based on diy rear projection tv idea) dion_lilley Parts 0 4th July 2007 01:34 PM
Wondering if Upcoming DIY design will work with Tubes? Cheap DIY Kits? demon2091tb Tubes / Valves 28 7th December 2005 05:51 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
