Grounded grid stage in guitar amp - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 9th September 2012, 01:56 AM   #1
Default Grounded grid stage in guitar amp
I'm trying to figure out the effect of the grounded grid (effects return) stage in the soldano super lead 60 schematic I found at EL34world.com.
Also, the following triode is a puzzle. It has a 100k resistor on both anode & cathode with grid connected to previous grounded grid anode at B+.
What happens in these 2 triodes as they overload?
JimG
Old 9th September 2012, 02:03 AM   #2
Here is a pdf of the schematic. V3 a&b have me intrigued.
JimG
Old 9th September 2012, 03:47 AM   #3
jjman is offline jjman  United States
That can't be correct I believe. It would put dc on the effect return from the cathode side of R18. I suspect a schematic switcharoo. Not an official one right?
Old 9th September 2012, 04:50 AM   #4
benb is online now benb  United States
I agree about the DC, and more, I guarantee that schematic is wrong. Even if the return were meant to be a "cathode input" the plate goes directly to B+ and so there's no signal going to the grid ofV3b.
Now I see the disclaimer about accuracy in the lower left corner.
If there's a forum at that site, ask there. Someone may have a corrected version of the schematic.
Old 9th September 2012, 02:43 PM   #5
DF96 is offline DF96  England
Either a deliberate spoiler, or very clumsy reverse engineering. V3a grid and cathode have been swapped, and R21 should be in V3a anode not V3b anode.
Old 9th September 2012, 06:46 PM   #6
Tubelab_com's Avatar
I have never seen a Soldano schematic with their name on it. I suspect that all the Soldano schematics on the net are reverse engineering derived. That one has the previously mentioned obvious mistakes. I have another (different) Soldano schematic on my hard drive somewhere that has a few questionable "features".
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 10th September 2012, 09:19 AM   #7
So soldano doesn't have a magic grounded grid stage. Can a gg be overdriven? What would that look like? Wouldn't have grid current limiting.
Ever been used in a guitar amp?
Old 10th September 2012, 10:19 AM   #8
No, it's just drawn wrong - VERY wrong
I wouldn't have thought so - I can't see any need (or advantage) in ever doing so?. Grounded grid gives you a low input impedance and a high output impedance, neither of which are of any value in a guitar amp.
You could certainly overload gg just as with any configuration, I don't know as it would make any difference or not?.
Nigel Goodwin
Old 10th September 2012, 12:13 PM   #9
I have never seen a magic grounded grid stage. Ordinary grounded grid stages are often used in valve-based UHF receivers such as 1960s TV sets.
Yes, a gg stage can be overdriven. I presume it would cause signal clipping.
My guess is that gg has never been used in a guitar amp, except possibly by accident - someone blindly copying a bad case of reverse engineering?
Old 10th September 2012, 09:18 PM   #10
Enzo is offline Enzo  United States
Look at the parts. Someone confused the two triodes. R21 and R19 belong to the left triode, plate and cathode. R18 and return signal go to the grid, not cathode. SO the right triode plate goes to B+. And step back and you have a VERY conventional gain stage with 1 meg grid return, a 1k cathode and 100k plate load. Plate direct coupled to VERY conventional cathode follower driving the tone stack.
What is drawn there is totally a fiction, born of error on the drawer.
Grounded Grid TRANSCENDENT line stage widi Tubes / Valves 12 12th September 2012 08:41 PM
Grounded Grid pre amp-- help please andrewe1 Tubes / Valves 10 17th April 2004 03:37 PM
Copyright 1999-2017 diyAudio
