Designed 12AT7 Long Tail Pair phase inverter - half of it doesn't work right - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 13th September 2012, 05:43 AM   #11
Struth is offline Struth  Canada
Banned
Hi Ramble
Your schematic is missing a connection at the top of the 10k.
Later splitters with 12AT7 have 47k plate loads, but the T works better than an X in either circuit providing the most clean output.
The original quiescent point selected by Jule is way too low. You have to acommodate the internal plate resistance which effectively reduces the potential signal swing. The tube cannot pull its plate all the way down to its cathode, like a BJT or mosfet can for their respective high-current paths, so the idle voltage has to be set to about two-thirds B+ for a symmetric output. This can be adjust by tweaking the cathode bias resistor.
Have fun
Kevin O'Connor
Long tailed pair phase inverter issues Kay Pirinha Tubes / Valves 6 19th March 2012 05:26 PM
Long Tail Pair mr2racer Tubes / Valves 13 11th February 2012 03:38 PM
Long-tail pair phase splitter sdinfo Tubes / Valves 14 21st September 2010 12:35 AM
Is a Differential Pair (CCS tail) phase inverter suitable for a Class AB outputstage? stigla Tubes / Valves 7 27th March 2007 01:57 PM
Long Tail Pair Phase Inverter with Penthode ? Yvesm Tubes / Valves 4 7th February 2006 09:15 AM
Copyright 1999-2017 diyAudio
