Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 21st August 2012, 09:52 AM   #1
ivan H is offline ivan H  Australia
Default JTM45/50 build, B+ question
Just starting JTM45/50 build using marshall bluesbreaker reissue PT. The origonal's schematic show a 0.05uf, non polarized cap from B+ to earth b4 the standby switch, the reissue has just the fuse & standby switch without the cap. I have a Mallory 150, 0.047uf, 630VDC cap. My question is is this cap suitable to use for this & is it preferable to add the cap to earth or not. Any help appreciated. Cheers
Old 21st August 2012, 12:19 PM   #2
It should be suitable, but I suspect it does nothing worth mentioning anyway
That's why it was left out of the reissue.
Nigel Goodwin
Old 21st August 2012, 04:09 PM   #3
Ok, thanks for thay Nigel. Cheers
Old 13th September 2012, 05:19 AM   #4
Struth is offline Struth  Canada
Hi Guys
Much of what the 47nF does depends on where the s/b is in the circuit. Typically the s/b is placed at the rectifier output ahead of the main filter. It is advisable to add a 330k-2W to ground from the rectifier output to avoid cross-conduction failures of the rectifier while in standby. You should also add a series diode between the s/b and the filter caps. This keeps DC off the switch, extending its life and eliminating pops.
A more useful position for the s/b is as a cathode lift for the output tubes.
Standby switches are not really needed in guitar amps. It's a wonder they were ever put in in the first place. Certain safety agencies around the world demand removal of s/bs before the amp can be sold in that country.
have fun
Kevin O'Connor
Old 19th September 2012, 05:13 AM   #5
Hi Kevin, thanks 4 the info, appreciated. Amp is built on Metro Amp chassis. Winged C EL34's cathode only tied to earth, pin 1 tied to the apex of 220k bias feed resistors, biased to 38mA by voltage drop across primary halves/resistance of primary half method . Question, do any problems arise from a long earth run to the EL34 cathodes, instability or the like? Cheers
Old 20th September 2012, 04:54 PM   #6
Hi Guys
Do yourself a favour and install cathode current-sense resistors so you can do safe ground-referenced measurements. The transformer-shunt method is doubly dangerous:
--the meter is floating at B+ so both leads are a shock hazard
--using an ammeter in a high-voltage environment risks damage to the supply
--ammeter shunting half the OT makes the circuit unstable unless the splitter tube is pulled
...that's actually triple danger....
A long cathode lead is not problematic in most instances. You can assure that it will be stable by twisting wires with related currents together so their induced fields cancel.
TUT3 shows proper wiring methods for guitar amps that minimise noise and maximise note articulation.
Have fun
Kevin O'Connor
londonpower.com
Old 20th September 2012, 10:27 PM   #7
Hi Kevin, thanks 4 the answer. I've just ordered acouple of ur books if ur that guy. I was aware of "twisting leads", I'm pretty happy with how amp sounds. I biased by; note resistance of OT primary halves, read voltage drop across each half & divide by resistance of that half, as suggested by Tone Lizard. Averaged both tubes to 38mA. I have ordered close tolerace 1 ohm resistors, I'll install when its time to retube. Cheers
Old 20th September 2012, 11:37 PM   #8
Hi again. I just had a quiet think 4 a sec & although it isnt the common method of biasing by shunting half of the primary with an milliamp meter, it is still a shunt method, just with a volt meter. I had intended installing 1 ohm current sensing resistors but after checking a dozen or so each of 1 & 2 watters that I had with a low ohm meter I couldnt find any I was happy using. Thanks for the tip about removing the phase inverter tube. Cheers
Clone of JTM45 davorin Tubes / Valves 8 9th December 2010 06:47 PM
Gibson GSS-50 speaker question Louie7 Instruments and Amps 4 24th January 2010 09:34 PM
Need woofer advice for Alpair 50 wide range build tybox2000 Multi-Way 3 24th November 2009 06:25 PM
JTM45 clone Jean-Paul_2 Tubes / Valves 0 11th June 2009 06:08 PM
Stuart and Neil Build a KSA 50 (tweaked for 100 watts) neil_kaye Solid State 12 11th November 2008 01:51 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
