Could the SA-310 bass cab be used for a bass and guitar cab? - Page 2 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 16th August 2012, 12:26 PM   #11
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
one simple guitar cab, for guitar
and adding exstra woofer cab, maybe with built-in power amp, whenever needed
it gives you more and better options, for whatever job you have
Old 17th August 2012, 09:47 AM   #12
chris661's Avatar
Originally Posted by JThompson56 View Post
I am trying to avoid having multiple rigs as I play bass, electric and acoustic guitars. I play worship music most often direct through the pa with my pedalboard. But I do need a rig for when I play outdoor shows, coffee houses, etc. I don't have the storage space for two or three rigs.
Would it make more sense to get a 4x10 cab with a freq range of 45hz to 5khz?
Is the Bassman Reissue still reguarded as a decent bass amp? I know they have changed the classification as its typically used for guitar these days.
You can probably get better for bass guitar: the speakers are in an open-back enclosure, so you won't get much in the way of low end out of it.
I use a sealed 4x10 cabinet and a 300w Laney amp for both guitar and bass. One of the speakers is a dual-cone one that extends out to ~15kHz, making it usable as a half-decent PA system.
Its great for band practice as I put the mixing desk in the fx loop and then iPod, mics, even electric drum kits into the mixer.
Chris
Old 17th August 2012, 05:29 PM   #13
Chris's solution sounds good, or for portability, two 10s and a tweeter.
This assumes you don't need a guitar speaker if you can get a good sound going direct, and that you'll be mic'd outdoors.
Old 17th August 2012, 08:38 PM   #14
Originally Posted by Keriwena View Post
...... two 10s and a tweeter.
then I would suggest two 10s, and yet another 10" for the 'tweeter job'....and the upper 10, you can make that one open back, if you wish
Old 17th August 2012, 09:50 PM   #15
Or maybe a 6", like the Eminence Alpha 6A.
That raises the question, Mr. Thompson, what sort of amp are you using? Tube, or solid state?
.... and the upper 10, you can make that one open back, if you wish
Good idea, especially for the acoustic guitar.
Micing a ported guitar/bass cab? qingcong Instruments and Amps 23 24th March 2011 12:34 AM
any electric bass players? im building a bass guitar cab KOA Instruments and Amps 27 30th April 2007 04:49 PM
Bass Guitar Cab Conundrum croat47 Multi-Way 0 7th November 2006 08:40 PM
bass guitar cab random_id Multi-Way 6 23rd July 2004 12:30 AM
Copyright 1999-2017 diyAudio
