Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 2nd August 2012, 08:21 PM   #1
Default Building a spring reverb unit
Hi
i am in the midst of making a spring reverb unit, it is my first electronics project and i could use some help from some people who are more knowledgeable on the subject than i am.
i have an Accutronics reverb tank model 8DB2C1D and i have some preamps from maplin. So far i have got the reverb driver, and the recovery amp working, but there are some modifications and additions i would like to add, but don't quite know how to go about it.
For the reverb driver i have used a 1 watt amplifier N48FL (see attachment)
I have got this to drive the strings in the reverb tank quite nicely but only when i power it with a 12v dc supply connected in parallel with a 9v battery.
For the recovery amp i have used a low noise stereo preamp N47FL (see attachment) this amplifies the reverberated sound nicely as well, I am also powering this preamp with 12v dc in parallel with a 9v battery.
i would like to add an op amp mixer so i can control the wet/dry mix using pots. Can anybody advise me on how to go about this please?
i have attached the pcb data sheets and a picture of my project so far
thankyou
leroy
Old 5th August 2012, 06:00 PM   #2
if you need another battery in parallel, it sounds as if you dont have enough current available in the power supply, and 9v battery on a 12v supply cant be doing anything any good.
looks like the recovery amp has a volume control so this would control the "wet" signal, so you just need a summing amp, which is a standard inverting op-amp gain stage but with a paralleled input
Old 6th August 2012, 05:11 PM   #3
thanks, ive got myself an inverting op amp for the summing amp, and a new power supply, im going to put it together tonight and see how it goes
Old 7th August 2012, 04:59 PM   #4
Here you will find the desired informations, I think. Go to APPLICATION and be happy!
Best regards!
Building guitar with spring reverb inside heavyrocks Instruments and Amps 5 27th January 2010 10:56 AM
building spring reverb Redfoxfur Instruments and Amps 26 24th June 2009 04:07 AM
Spring Reverb Units TGRANT Solid State 11 4th March 2009 11:31 PM
Spring Reverb transformer ThSpeakerDude88 Tubes / Valves 6 18th April 2007 03:17 AM
Transducers for a spring reverb seilee Instruments and Amps 3 5th December 2006 02:56 PM
Copyright ©1999-2013 diyAudio
