| Instruments and Amps Everything that makes music, Especially including instrument amps. |
Hi
i have been building the following layout: http://www.turretboards.com/layouts_.../stock_mod.pdf today i powered it up for the first time... after some waiting... nothing.. no sound.. no buzzing or humming... nothing... and then some smoke :-) i then replaced the burned resistor. (first resistor 1K over the first cap. 22uf 450v.) i have checked everything again, for the 15th time and the i noticed i had the ground of the OT connected to the green wires... so i cut the wire and powered up the amp. no smoke, still no sound. very careful i felt the 1K resistor, it was hot, but not burning. the i switched the amp off and accidentally i bumped my guitar, and then i heart sound slowly fading out. now what did i miss? i really could use some suggestions... |
#2 | |
Plenty of them, that shows everything. You have a mistake somewhere that produces a short circuit. You should not have replaced the resistor, and turned it on again. Not until you find the mistake. You have another part burned out and it could be the transformer. DO NOT operate the unit, until all the connections have been verified. PHOTOS? PHOTOS? You can make this much worse than it is, by turning it on again. Operating the amp without a speaker load will blow the output transformer, bingo. Last edited by soundguruman; 2nd August 2012 at 05:25 PM. |
#3 |
The caps in the layout do not show any polarity symbols. How did you orient them?
Do you have any kind of Volt meter? |
#4 |
soundguruman thanks for your reply, but i really can't take good photos of this build. it's all soldered to the tube sockets.
i'll order a turretboard and start over just to be on the safe side. |
#5 |
@loudthud
most of the parts came from the original PCB. i looked at the polarity and matched it to the layout drawing. and yes, i do have a volt meter. |
#6 |
There are no polarity makings on the layout. I have marked polarity on the attached layout.
Voltages at the tube socket pins would go a long way towards revealing where the problem is, but you may do damage to the amp while taking the readings. Check the polarities against the diagram. If any caps were installed backwards, they are damaged now, replace them with new ones. |
#7 |
thanx Loudthud i am going to check it again tonight.
#8 |
ok i've checked everything twice. all de caps are in the right place with the correct polarity.
but still the same thing... i wait nothing happens.. i turn of the power, and then it briefly comes to life. |
#9 |
You have something wrong in the bias supply. When you turn it off the bias supply is dropping faster then the B+. at some point the voltages are right for the tube's to conduct and you get sound.
#10 |
| Fender FM 212 popping sound when switching off | nilhegar | Instruments and Amps | 3 | 10th January 2012 08:48 AM |
| Linear or switching power supply in Sound Process | steven2583 | Power Supplies | 12 | 11th November 2011 10:22 PM |
| Wanted : UCD /ICE / Zap Amp/ switching amp Modules | Magnetar | Swap Meet | 0 | 7th February 2006 03:02 AM |
| Amp Input: XLR & RCA switching | Devil_H@ck | Digital Source | 5 | 29th May 2004 08:54 PM |
| The sound of two transistors switching | mikelm | Solid State | 34 | 12th February 2004 04:18 PM |
