How to improve marshall guitar amp with harsh overdrive? - Page 3 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 28th November 2012, 09:04 PM   #21
Not sure why you are replying to a thread 4 months old, but it's patronising to tell me what to do in the manner you write.
I asked what was possible - people already made good suggestions.
fyi the amp has a closed back and I already have another amp
Old 29th November 2012, 09:59 AM   #22
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Good, you did the right thing.
Old 29th November 2012, 06:46 PM   #23
Originally Posted by teemuk View Post
You can achieve a lot by modifying rest of the circuit. Basically a lot of the tone is based on shaping the frequency response in the first gain stage, in the tone control circuit, in the 2nd order filters and in the power amp. The O/D is basically just routing the signal through a moderately high bandwidth stage that clips. As is it would be pretty much "fuzz". A lot of the tone shaping towards "metal" territory takes place elsewhere in the circuit... However, modifying rest of the circuit will consequently have it's effects on the clean tone as well.
You might try boosting the treble (which is practictically achieved by limiting bass) very early in the path, before the clipping stage. Then you can cut the treble back in later stages. Think of it as pre-emphasis and post-de-emphasis with the distortion generation in-between. That gives you some independent control of the tone of the distortion. The basic guitar tone comes thru with treble boosted and then cut, relatively unaltered. The stages in between that generate complex harmonics start with the harmonics in the boosted treble, then those harmonics 'beat" against each other for interesting sounds, but the distortion generated inbetween the pre-emphasis and post-de-emphasis stages only gets its treble cut. The result is a mellower distortion without so much fizzy irritating treble.
You might also consider adding an early effects loop to just that channel, and putting the distortion diodes on a switch. You could try plugging in various compressors and/or real tube stomp-boxes at a more ideal point in the signal path instead of only at the guitar.
Just a few things to be mindful of. Using two tone stacks, before & after the clipping, is kind of my 'thing'...other equally valid opinions and techniques proliferate.
Guitar amp problem (marshall 8080 valvestate) Palmu85 Instruments and Amps 3 26th September 2011 09:33 PM
Tube overdrive for guitar/bass MellowTone Instruments and Amps 4 4th October 2009 10:03 AM
Marshall guitar amp. Upgrade IC's recommendations Joelg Instruments and Amps 8 22nd January 2009 11:48 PM
Marshall 100v 8100U Guitar Amp Hums DreadPirate Instruments and Amps 0 29th January 2007 02:20 PM
turning an ibanez guitar amp to a marshall electro samurai Instruments and Amps 0 5th June 2004 08:33 AM
Copyright 1999-2017 diyAudio
