trainwreck speaker baffle reduction - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 3rd July 2012, 09:19 AM   #1
bullpeters's Avatar
Default trainwreck speaker baffle reduction
Got a really nice 2watt wreck that i want to put into an existing combo cab. The cab has 220mm whole in baffle! I need 270mm for a nicely broken in Lorantz driver. What effect will choking up the hole have? Glad to lose some SP even tho
its only 2 watt dirty, its still F O loud. speaker guru,s please pronounce
Old 3rd July 2012, 10:38 AM   #2
tsiros is offline tsiros  Greece
tsiros's Avatar
Send a message via MSN to tsiros Send a message via Skype™ to tsiros
I do not understand a single word.
Maybe because i am not a guru?
Old 3rd July 2012, 11:33 AM   #3
bullpeters's Avatar
sorry.
what will happen if i put a 270mm Diameter speaker in a box with a 220mm hole in it?
good things or bad things?
good things would be the same sound, less volume.
bad things would be anything else i suppose
Old 3rd July 2012, 11:36 AM   #4
bullpeters's Avatar
sorry for my bad expression.
Old 3rd July 2012, 12:52 PM   #5
tsiros's Avatar
I think it will sound better
but i could be wrong
Old 3rd July 2012, 01:07 PM   #6
bullpeters's Avatar
thanks for your input,
Old 3rd July 2012, 01:58 PM   #7
chris661's Avatar
Depends.
I did this with a cabinet that had holes for 8" drivers, and rear-mounted 10"s in it. When I played loud bass guitar, the cones came forward and hit the front baffle, so I got a chisel and removed wood from the front baffle until the cones stopped hitting.
If there's enough spacing between the cone and the baffle, you'll be fine. This is for guitar, right?
Old 3rd July 2012, 04:29 PM   #8
It will probably work fine if the 10" is a suitable guitar speaker.
Some like open backed, some closed back, some both, YMMV.
rgds, sreten.
Chill-Baffle speaker (L-baffle design) fedde Full Range 7 26th September 2010 01:38 PM
Schematic question (Trainwreck) dosilegecko Instruments and Amps 3 2nd April 2010 02:19 PM
trainwreck lpd Instruments and Amps 1 15th September 2009 12:31 AM
Reduction in Speaker Output Tigerthetony Solid State 1 26th February 2008 06:38 PM
Next amp build - Trainwreck - Princeton - Deluxe ??? gtrbryan Tubes / Valves 9 15th October 2006 07:07 PM
Copyright 1999-2017 diyAudio
