Help needed identifying 1962 marshall bluesbreaker (reissue) power tx connections - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 2nd July 2012, 07:10 AM   #1
ivan H is offline ivan H  Australia
Default Help needed identifying 1962 marshall bluesbreaker (reissue) power tx connections
Hi, I ordered said power tranny 2 use in a home build amp as it has GZ34 rectifier. Recieved tranny TXMA 00109. Connections on 1 side r 3x 6.4mm spade lugs being center tapped 6.3vac heater supply & 3x 3.2mm spade lugs(?) being center tapped 350vac a side HT supply. Also on this side r 2x black insulated multi strand leads (unknown). 5vac rectifier heater supply maybe? On the other side r 2 pairs of connections. 1 reads 4.2 ohms, the other 4.7 ohms. Maybe 2 halves of the primary winding, 1 at 120vac & the other needing to have the connection bridged for 240vac operation. Any help will b greatly appreciated. Cheers
Old 2nd July 2012, 07:06 PM   #2
Enzo is offline Enzo  United States
Beats me. Here is your schematic - parallel for 120v adn series for 240v on the primary side. And here is the wiring for an older transformer. The resistances may be instructive there.
Old 2nd July 2012, 09:49 PM   #3
Thank you Enzo, that about wraps it up. The secondry 6.3vac heater supply & 350vac a side high voltage supply were unmistakeable, & the 2 flex leads exit the windings either side of the 6.3vac center tap & read 0.9 ohm, obviously for connection to the rectifier valve base directly adjacent to the tranny. I was reasonably sure the middle 2 connections of the primary needed bridging to put the 2 windings in series for 240 volt opperation, you have just confirmed this. Thank you. Cheers
what tx needed paul.42 Solid State 3 24th October 2011 08:29 AM
Blown Bluesbreaker batsong Instruments and Amps 6 22nd June 2011 03:02 PM
5U4 Darling power TX advice needed waam68 Tubes / Valves 2 14th December 2008 07:15 PM
Help needed in identifying MOSFETS Archimedes Car Audio 10 15th December 2006 08:11 AM
Identifying output tx. Trebla Tubes / Valves 3 29th September 2006 10:16 PM
Copyright 1999-2017 diyAudio
