AVT50 Repair - Page 4 - diyAudio
Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 23rd July 2012, 06:06 PM   #31
Could you be more specific?
Old 23rd July 2012, 10:29 PM   #32
Enzo is offline Enzo  United States
As it sits it makes loud hum. That is almost always either DC on the outpout or bad filter caps. DC will make the speaker cone move one direction and stay there. If it does that, TURN IT OFF. Disconnect the speaker. If it doesnlt do that, we move on.
Never connect a speaker to an amp until you knoiw it is not making DC on the output. Measure for DC voltage between the speaker wires while it is running. Should be none.
If no DC offset, then you have probably lost filtration. even if you replaced the caps, there may still be a bad connection to them or a cracked solder or circuit trace connetion.
The AVT50 uses the little power amp ICs TDA7293 on the very small circuit board mounted to the heat sink. Fan cooled. The little circuit board with IC I call a power module. It connects to the main board via cable. If there is DC on the output wires, than almost certainly this TDA7293 is bad.
Old 24th July 2012, 12:05 AM   #33
Thanks. I will do some more checking.
Old 12th December 2012, 10:09 PM   #34
I, I have an AVT 50, and it keeping blowing fuses when poweramp is connected. I changed BR, fuse (6 times) and Tda7293( twice) ..so, Im checking deeply and found that on LT+ it has 32V DC but 67V AC ??? Is it normal ?? ...On LT- is -32VDC with 0v AC.... Could you help to find out if it something wrong?? Any idea to solve this issue?
Last edited by moonmark; 12th December 2012 at 10:24 PM. Reason: grammar corrections
Marshall AVT50 Mods JakeAC5253 Instruments and Amps 6 18th December 2014 12:46 AM
Marshall AVT50 Pops when Switching Channels morta Instruments and Amps 2 7th October 2010 04:13 AM
Marshall AVT50 Pops when Switching Channels morta Instruments and Amps 0 1st October 2010 12:50 AM
Getting better EQ on a Marshall AVT50 Fr_3_aK Instruments and Amps 15 3rd January 2009 10:01 AM
MARSHALL AVT50 mod. Vahagn Instruments and Amps 4 28th January 2006 06:52 PM
Copyright 1999-2017 diyAudio
