| Instruments and Amps Everything that makes music, Especially including instrument amps. |
hi all its me again...
this time I want to be help about eq... in my attachment is tone control using opamps... How to make that circuit work with jfet ??? why I chose jfet because I want solid state with tube taste ![]() I want use it for clean chanel,but if any member want to help me with make me two chanel (overdrive&clean) i'll be more apriciated,and will use it all the time.... all input will be some big help to me... thanks.... |
#2 |
It allready uses a Jfet , The TL082 is a Jfet opamp .....
PS:The second half of the TL082 should be configured as an input buffer ..... |
#4 |
Just use a JFET source follower as an input buffer. You need to drive the circuit from a low impedance anyway.
#5 |
thanks all ... But I mean I'm try to build that tone with transistor (j201) cos many schematics was using stack tone,in this case I want that circuit build with j201 or similiar,cos I thinks playing with transistor more easier than playing with opamp,what about that???
#6 |
Actually the opposite is true!!
Opamp's are easier to work with than you lead yourself to believe !!! I am not good at Jfet amplifiers but if you want to use a one in the circuit you can place a Jfet amplifier in place of the opamp as long as it inverts the signal. I have no idea how to set or determine the gain of a Jfet amp but if it is not an inverting type amplifier you most likely will have an oscillator. FWIW jer
#7 |
looks like a baxandall feedback control(active)
modded to have 2 bass controls usually theres only one bass, and one treble so the question is, will it work properly or is it a theoretical design ? hey, Im into trying one myself, and really interested in this
#8 | |
![]() its very similar to the tilt control used in Quad preamps I think it only needs one mutual control to work like a tilt |
#9 |
will show up on google
by the hundred ![]() I think the type of jfet you use is mostly determined by your voltage j201 should be good for low voltage like 9V other jfets may work better on slightly higher voltage depends on how you plan to use your design battery or regulated supply, outboard, onboard, built in, etc etc well, I see the one in your tone control uses symmetric +/- supply so I guess a low voltage battery supply is not your goal ? |
#10 |
Some schematic using jfet (j201 or similiar) was 15v to 24v,but using tone stack,then I find that attachment, so I want modify that as I want,any picture or attachment to make easier to build that.... Please.
