| Instruments and Amps Everything that makes music, Especially including instrument amps. |
I've got a solid state bass amp that, when you boost the treble, will self oscillate if the gain is high. The severity depends on what impedance is connected to the Hi Z input, but would this be common or acceptable? I'd think a manufacturer would be very reluctant to put out a product where some control combination could cause self-oscillation. OTOH, with the amount of boost available, it might be hard to prevent. I know a lot more about hi-fi amps than instrument amps, so enlighten me!
I used to be an audiophool like you but then I took an arrow to the knee. |
#2 |
Ultimately you are dealing with a manufactured product. Things happen in the manufacturing process far from the eyes of the people that designed it. Parts get substituted where price is the most important specification. Checkout procedures are written so people without technical training can do functional checkout of finished products. The people manufacturing amps may not understand what it is or how it is used. This happends frequently when manufacturing is moved offshore and the parent company receives amplifiers boxed for shipping on pallets. Sometimes they are shipped straignt to distributors. I'm surprised more don't burst into flames when you plug them in.
#3 |
If it oscillates then it's faulty - take it back abd have it replaced.
Nigel Goodwin |
#4 | |
Later versions of this amp had a small ceramic cap (few pF) somewhere in the preamp to cancel this. So yes, it sometimes happens. YMMV |
#5 |
not so sure it is defective. i would love an explanation, but with the mountains of gain with some of these amps, it is inevitable.
have you ruled out feedback from your bass? |
#7 |
I had a Sunn Coliseum Slave that did that.
It did to the owner and only once for me. So, I cleaned it and Sprayed the controls out and reseated all of the connectors to the board. As far as I know it has never done it again. I don't know exactly what the cause was but it never came back. I also had a Peavey Renown 400 the destroyed a speaker because of ultrasonic oscillations. The cause of that was a bad Molex connector to the board. So, I cut the connector off and soldered the wires directly to the board and it never did it again. FWIW jer
#8 |
Ah ha, so it does happen. This is an older amp and it oscillates with a sig gen on the test bench, so acoustic feedback is highly unlikely. I've got a message in to the manufacturer to see what's normal. The amount of gain is tremendous when you boost the treble, and there are three ways to do that- treble control, "bright" button and a 5-band equalizer. I'm not above adding some non-factory shielding if it would help. Thanks!
#9 |
It Is hard to tell without seeing it or a schematic, But my guess would be maybe a cracked trace or bad solder joint somewhere.
If it as a Graphic eq or any eg for that matter if the negative feed back path is open this could cause to much gain and cause it to oscillate. I had described a little about this here, little help here little help here Check the control to see if maybe the element has worn out or had opened on one end. As this could cause it to be separated from the negative feedback path making it only have a positive amount of gain. jer ![]() P.S. In some eq circuits there there is a positive feedback return path and a negative feedback return path unlike the link above. Last edited by geraldfryjr; 25th June 2012 at 06:04 PM. |
#10 | |
Sometimes this is cured by selecting the proper grade tube for V1A, selected for low microphonics. Installing a 7 pf, 1000V cap, between plate and grid (between pin 2 and 1 OR pin 7 and 6 on a 12AX7) is a very widely used snub circuit. This design was used by both Fender and Marshall to prevent squealing oscillations. That's what you were looking for. The cap should be a high grade silver mica, soldered directly to the pins of the socket. Production amps use a ceramic disk capacitor. This is ONE of the techniques used by manufacturers to stop the ringing. |
| Why do solid state guitar amps need so many op amps? | razorrick1293 | Solid State | 2 | 8th June 2011 10:06 AM |
| Guitar amps | harrygrey382 | Instruments and Amps | 25 | 7th July 2007 06:35 PM |
| Why do some Bogan amps sound so good as guitar amps? | amperex | Instruments and Amps | 7 | 22nd June 2006 11:46 AM |
| guitar amps | electro samurai | Solid State | 2 | 5th May 2004 02:32 PM |
| Op Amps in Solid State Guitar Amps | MrGuitardeath | Instruments and Amps | 1 | 11th February 2004 07:43 PM |
