Go Back   Home > Forums > Live Sound > Instruments and Amps
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 12th June 2012, 02:56 PM   #1
Question 2Ж27Л - 4Ж1Л - 12Ж1Л - 4П1Л - How to use ??
I've some of this tubes
and I'm interested about to use for an amp (guitar amp)
So I'm looking for schematics
however any proven audio schematic using this tubes is of interest for me
Kagliostro
Old 12th June 2012, 03:24 PM   #2
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Here is an example:
One more 4P1L SE
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative.
Old 12th June 2012, 05:40 PM   #3
kevinkr's Avatar
Moving to Instruments & Amplifiers since first post specifically mentions guitar amp. Please read the headers atop both tubes/valves and Instruments & Amplifiers for the reason why. It's clearly stated.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 12th June 2012, 06:04 PM   #4
Hi Wavebourn
That is an interesting drawing, a bit complicated if compared to the schematics I'm used to see (guitar amp schematics, not Hi Fi amp), but interesting, many thanks for sharing
@ Kevinkr
I apologize , thanks for moving in the right section
Kagliostro
Old 12th June 2012, 06:16 PM   #5
tinitus is offline tinitus  Europe
Originally Posted by Kagliostro View Post
Hi Wavebourn
....a bit complicated if compared to the schematics I'm used to see (guitar amp schematics....
not really....if you know what you are looking at
Old 12th June 2012, 06:19 PM   #6
Wavebourn's Avatar
Yes, for guitar amp it is no good. It is high-end amp, used in well controlled listening. Driver stage has negative swing limited by negative voltage supply, so clipping will be hard and harsh. For guitar you may use 12P17L and 12J1L similarly to Fender Champ schematic.
Old 12th June 2012, 06:26 PM   #7
Kagliostro
when you google, I suggest you try go to 'pictures'
often gives some good hits
Old 12th June 2012, 09:18 PM   #8
That is a good council I often do that and .......... yes, that way I've also seen the schematic drawn by Wavebourn
About the complication at which I was referring Wavebourn has perfectly understand what I was intending (as from his answer)
about the use of 12J1L (12Ж1Л) I've one, but no 12P17L (12П17Л)
May be I can use the 12Ж1Л + 4П1Л like in this schematic, but sure I need councils as to use for guitar instead than for his original purpose
(hope someone can give indications about)
Kagliostro
Old 13th June 2012, 05:18 PM   #9
Wavebourn's Avatar
You can use 12Ж1Л + 4П1Л like 6SJ7 + 6V6 in Fender Champ schematic. However, you will need 2 different filament voltages.
Old 13th June 2012, 06:37 PM   #10
Hi Wavebourn
The direct cathode heater of the 4П1Л is confusing me
a bypass cap isn't necessary ? (Fender 5C1 6v6 cathode = 500ohm + 25mf)
Kagliostro
Question regarding my SONY TA 1055 spokes1979 Multi-Way 0 22nd March 2011 04:19 AM
Sony ta-1055 issues Spytap Solid State 4 12th June 2010 05:20 AM
WTB: JFETs: КП801, КП802 aka KP801, KP802 Faust3D Swap Meet 4 13th January 2010 12:57 PM
Question about Sony TA-1055 jonjonjonjon Solid State 3 28th September 2007 01:20 AM
sony TA 1055 LAO Solid State 1 30th August 2004 04:54 AM
Copyright ©1999-2013 diyAudio
