| Instruments and Amps Everything that makes music, Especially including instrument amps. |
#11 | |
#12 |
doh! you are correct, i ommitted that part. honestly, I do not know the answer to that question. I know the bias on 5150II/6505+ is adjustable stock, but not as hot as some like it. the mod basically makes it so you can bias hotter.
#13 |
Plate voltage is also a variable in figuring out plate dissipation. How do you know the tubes are pulling 37ma? Do the power tubes share a common low ohm resistor in series from cathode to ground? You are not giving us enough information to help you.
#14 | |
I have no physical means of proving the mA draw, just the information that was provided by the seller. Thanks anyway guys. |
#15 |
But how much would a tech ask you for doing this for you? (excluding the tubes)
#16 | |
I had assumed, perhaps prematurely, that since the bias was already set, if I just needed a new set up power tubes, would I be able to just pop out the old set, pop in the new, and then power up without having to re-bias anything, assuming that I was able to procure identical manufacturer/model. Its sounding like there are a bunch of other factors to consider. |
#17 |
150$ !!! I want to immigrate!
Seriously, you sure can pop in a new set. Espexially if they re the same make, nothing can go too wrong. Just buy them matched, and don't lose your sleep anout that. Do some homework, too, seems it will really pay off Tales From The Tone Lounge:Biased Opinions |
#18 | |
#19 |
Moved per forum policy from tubes/valves to Instruments & Amplifiers. Please read the header at the top of each forum for why.
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
| help with peavey 5150 bias adjustment | YonjaminYodle | Instruments and Amps | 7 | 9th March 2012 06:17 PM |
| B&K AV6000 Sers II Running HOT | kybassmaker | Solid State | 0 | 13th August 2011 11:24 AM |
| new head unit getting really hot | roundeye69 | Car Audio | 11 | 18th March 2011 11:21 PM |
| bias amp while hot or cold? | nicksmurf | Solid State | 5 | 28th June 2003 07:56 AM |
