| Instruments and Amps Everything that makes music, Especially including instrument amps. |
Hello all, I am going to build an amp with parts I have lying around. I have a hammond 270BX PT
Specs here:http://www.hammondmfg.com/pdf/5c0026-27.pdf I want some schematic recommendations for an amp that would use this PT. Any insight would be helpful. I am interested in an EL84 amp. Though any design would be considered. Thanks and have great weekend!!!!!!!! |
#2 |
Check out the AX84 Co-op page: AX84.com - The Cooperative Tube Guitar Amp Project
I noticed the PS trans used is the 269EX, FWIW. jeff |
#3 |
You need to drop a loooot of voltage to bring the HV to el84 levels (320 MAX but for single ended applications more likely 250-280)
Only way I see it happening (other than big resistors), is with a choke input supply. Do you have an Output transformer? Last edited by costis_n; 1st June 2012 at 07:42 PM. |
#4 |
Hammond 270BX with a tube rectifier and C-L-C filter should be close to 320V B+.
Life is hard - Then you die. |
#5 | |
http://www.ampmaker.com/se-5a-constr...ual-948-0.html I would grab the documentation quickly, the amp seems to be not available anymore. Last edited by Printer2; 1st June 2012 at 10:00 PM. |
#6 |
For class A single ended with constant power supply load a correctly arranged LC filter will have a lot less output voltage than CLC or CRC. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#7 | ||
Moving to Instruments & Amps forum per forum policy. Please see forum headers. Quote:
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
#8 |
Sorry I thought I posted in the correct forum. I don't quite understand what you mean with C-L-C, and C-R-C. Im a newb and this will be my third single ended build. Thanks for the insight and inspiration.
#9 |
Power supply filter arrangement.
A typical basic power supply will have a rectifier feeding to a filter cap. Then from there usually we find either a resistor or an inductor (choke) to the next filter cap. Cap, resistor, inductor - those are what the C R and L stand for. CRC means cap through resistor to cap. CLC means same thing except a choke instead of resistor - cap choke cap. L is the symbol for inductors. For reasons you can look up (capacitor input filter versus inductor input filter) if the rectifier feeds to a cap first, the resulting voltage will be higher than if it feeds an inductor before it gets to a cap. Choke input filters are relatively uncommon in guitar amps. But going to that instead of a cap input filter is one way to lower the supply voltage simply. |
#10 | |
Experience is what teaches us to make a different mistake next time... |
| Compact Single-Ended Class A Build | inspiribomb | Pass Labs | 32 | 26th January 2009 02:57 AM |
| 807 single ended guitar amp | phuc-u.com | Tubes / Valves | 1 | 8th June 2008 07:52 AM |
| 5 watts single ended amp | renjiish | Solid State | 23 | 22nd January 2005 12:45 AM |
| single ended mosfet amp | KlausB | Solid State | 11 | 26th February 2004 07:47 PM |
